Re: Disc brakes A body,WILWOOD or scarebird?
[Re: challengermike]
#1104351
10/31/11 12:14 AM
10/31/11 12:14 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Iput the Wilwood HD kit on the front of my Demon.It stops great.I added the M/Cyl from Ehrenberg and left the rest as it came from the factory(prop valve lines etc.)The car isgoing back to street duty and the Wilwoodswill work fine there too.I went with the HD kit as my Demon has a 440 in it.
[Re: Chris2581]
#1104353
11/01/11 09:34 AM
11/01/11 09:34 AM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
Mines gong to have a 499 rb in it.So i think i might go with the scarebird kit and get some drilled and slotted rotors and some ceramic pads.Where did everybody get there disc brake prop valve from the junkyard off another a body?Also what master cylinder should i order?late a body?
[Re: radar]
#1104359
12/05/11 04:29 PM
12/05/11 04:29 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
The scarebird kit uses a shelf (forgot application probably on their website) rotor with an insert to fill the center hole (dodge spindle is smaller) and they give you a pattern to drill out the boltpattern.
That's what I thought , no thanks to that .
[Re: AndyF]
#1104361
12/05/11 05:42 PM
12/05/11 05:42 PM
JohnRR
Come on John, it isn't that tough. You just put the rotor down in the mud so to hold it firm, then you use a hand held drill with a rusty drill bit. If you don't have a big enough drill bit you just wallor out the hole a little bit by chewing on the sides. The wheels might wiggle a bit but nobody cares about that.
You're right , what was I thinking ....
I already have a set of rotors and hubs that were home drilled for large bolt pattern , wasn't done by me , with a small amount of runout. i'm going to return them back to SBP at some point so no big deal.
