Re: Piston Wall Clearance
[Re: GTMaracucho]
#110369
08/25/08 11:03 PM
08/25/08 11:03 PM
everything expands when hot. if the ring gap is to tight, it will bind up and lock the pistons in place.
The specs for kb pistons and ring gaps are on the kb site. just search it
[Re: GTMaracucho]
#110370
08/25/08 11:04 PM
08/25/08 11:04 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
.012".
Why??
I think thats around 4-6 thou too tight if not more.
[Re: Mopar-Al]
#110371
08/25/08 11:26 PM
08/25/08 11:26 PM
Posts: 309 Maracaibo,Venezuela
GTMaracucho
super street
super street
Maracaibo,Venezuela
I believe minimum clearance in .0015
But if your ring gap is too tight, a kb hypo will expand more and can bust the rings
But what about Piston Wall to Cylinder??? .007" It's OK???
[Re: Mopar-Al]
#110372
08/25/08 11:26 PM
08/25/08 11:26 PM
RapidRobert
From KB site: "street normally aspirated" forged pistons top ring-.016" 2nd ring -.012"
[Re: RapidRobert]
#110373
08/25/08 11:31 PM
08/25/08 11:31 PM
GTMaracucho
super street
super street
Maracaibo,Venezuela
Thanks....but I'm using total seal ring, is same??
[Re: GTMaracucho]
#110374
08/25/08 11:32 PM
08/25/08 11:32 PM
Mopar-Al
Alabama
.0015 thou
I do believe. This card says .0015
[Re: Mopar-Al]
#110377
08/25/08 11:48 PM
08/25/08 11:48 PM
GTMaracucho
super street
super street
Maracaibo,Venezuela
Did you make sure you had good engine/body ground cables and the right size? This particular question can bite a lot of people in the but.
I have the battery in trunk, and have only one ground cable, because the motor mount are metal without rubber.
[Re: GTMaracucho]
#110378
08/25/08 11:54 PM
08/25/08 11:54 PM
RapidRobert
could you hook up a batt up front so that when it is warmed up & acting up & dragging you can see if it's a voltage drop issue or an engine friction problem.
[Re: GTMaracucho]
#110380
08/26/08 12:15 AM
08/26/08 12:15 AM
RapidRobert
In your 1st post you have .007" ptw with forged pistons. What do you mean "in resume"?
[Re: RapidRobert]
#110381
08/26/08 12:20 AM
08/26/08 12:20 AM
GTMaracucho
super street
super street
Maracaibo,Venezuela
I'm confuse, .007" PTW is goood?? or .015" is the correct clearance??
[Re: GTMaracucho]
#110382
08/26/08 12:30 AM
08/26/08 12:30 AM
RapidRobert
in your 1st post you have .007 piston to wall clearance with your forged pistons, & in the next post you have .012 top ring end gap clearance, correct so far?
[Re: RapidRobert]
#110383
08/26/08 12:33 AM
08/26/08 12:33 AM
GTMaracucho
super street
super street
Maracaibo,Venezuela
Yes sir
[Re: GTMaracucho]
#110384
08/26/08 12:58 AM
08/26/08 12:58 AM
RapidRobert
on their(KB) site they want .004 piston to wall clearance on the top ring for each inch of bore with forged(not hypereutectic) pistons(If I am reading their site correctly,it was a little confusing) which would put you at .016" for a street normally aspirated application(the top ring). At .012 you are tighter than they recommend but I dont know if your rings are butting & causing the problem or not but the more I think about it I would be inclined to think the rear mounted battery & long cables are the culprit. When its warmed up it cranks too slow & this is the issue right? At that point in time could you pull the plugs & see how it cranks & also with the plugs out put a socket & breaker bar(or torque wrench) on the front harmonic dampener bolt & see how hard it is to turn ? or easier yet at that point in time get a jump directly to your starter & dont use your trunk battery & see what it does. It is midnight here & I am going to have to sign off. I will get back to you tomorrow. Post what you find out.
