Page 2 of 3 1 2 3
Re: Piston Wall Clearance [Re: RapidRobert] #110385
08/26/08 01:32 AM
08/26/08 01:32 AM
Maracaibo,Venezuela
GTMaracucho Offline OP
super street
super street
Maracaibo,Venezuela
on their(KB) site they want .004 piston to wall clearance on the top ring for each inch of bore with forged(not hypereutectic) pistons(If I am reading their site correctly,it was a little confusing) which would put you at .016" for a street normally aspirated application(the top ring). At .012 you are tighter than they recommend but I dont know if your rings are butting & causing the problem or not but the more I think about it I would be inclined to think the rear mounted battery & long cables are the culprit. When its warmed up it cranks too slow & this is the issue right? At that point in time could you pull the plugs & see how it cranks & also with the plugs out put a socket & breaker bar(or torque wrench) on the front harmonic dampener bolt & see how hard it is to turn ? or easier yet at that point in time get a jump directly to your starter & dont use your trunk battery & see what it does. It is midnight here & I am going to have to sign off. I will get back to you tomorrow. Post what you find out.
Thanks for your help..... Now I have in my hands somethink to do tomorrow
Re: Piston Wall Clearance [Re: GTMaracucho] #110386
08/26/08 02:38 AM
08/26/08 02:38 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
here are the real specs take your bore size and times it by .0065 to get your end ring gap, witch would be around 25,28 thou is were i set up small blocks.
MOPAR OR NO CAR
Re: Piston Wall Clearance [Re: GTMaracucho] #110387
08/26/08 02:48 AM
08/26/08 02:48 AM
hemigod426 Offline
hemigod426  Offline
ptw on kbs is 2-4 thou there designed to be tighter than forged i set up at 4-6 thou ptw, its where the top ringland in piston is machined that it comands twice the end gap for expansion if you dont follow that piston top will break off when under load and up to temp
MOPAR OR NO CAR
Re: Piston Wall Clearance [Re: hemigod426] #110388
08/26/08 08:54 AM
08/26/08 08:54 AM
dogdays Offline
dogdays  Offline
You didn't read the original post. He says the pistons are KB FORGED. He says he has 0.007" piston-to-wall clearance, I think that's too much, but it's the maximum in the KB chart for drag racing, 4" piston. He says he has ring gap of 0.012". The chart says 0.004" per inch of bore diameter, that would be 0.016" so the ring gaps are too tight.
R.
Re: Piston Wall Clearance [Re: dogdays] #110389
08/26/08 10:18 AM
08/26/08 10:18 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
he also said hard turning when hot...could it be a timing issue instead of a clearance issue?
**Photobucket sucks**
Re: Piston Wall Clearance [Re: 70Cuda383] #110390
08/26/08 10:39 AM
08/26/08 10:39 AM
excellent idea! Could it actually be something thatsimple as overadvanced timing On our stock car we had to engage the starter THEN switch on the ign to get it to crank when things were hot. If he grounds the coil wire & then cranks we'll have the ans to that.
Re: Piston Wall Clearance [Re: RapidRobert] #110391
08/26/08 11:13 AM
08/26/08 11:13 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
.007 on the pistons is ok, loose and mabye noisey when started cold, but ok. .012 on the top ring is bad, and technically, leaving the 2nd ring a little bigger than the top will help ring seal. So with a 360 (4.03 when bored .030 over) I'd be setting the top ring at .017 and the 2nd ring at .020. Also, always round up when you get a "point something" (4.03x.004= .01612, or .017). You want to err to the large side on any performance engine.
Re: Piston Wall Clearance [Re: RapidRobert] #110392
08/26/08 01:03 PM
08/26/08 01:03 PM
Maracaibo,Venezuela
super street
super street
Maracaibo,Venezuela
I have 34° and MSD 6 Digital Plus with retard option
Re: Piston Wall Clearance [Re: GTMaracucho] #110393
08/26/08 01:18 PM
08/26/08 01:18 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Clearance for piston to wall clearance is made
at the shirt not the top ring. Ring end gap is based on bore diameter as well. Forged pistons
are clearanced at .004 to 5 thousands.
The measurement of .0015 is 1 1/2 thousands.
.005 has been the sweet spot for forged pistons.
The piston materials used today are of much better
quality and grow less than materials used in yester year.
logan426
Re: Piston Wall Clearance [Re: GTMaracucho] #110394
08/26/08 02:46 PM
08/26/08 02:46 PM
That answeres that Q without even having to do anything.
Re: Piston Wall Clearance [Re: RapidRobert] #110395
08/26/08 05:58 PM
08/26/08 05:58 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
That 34degees is total advance, what is the initial advance, most engines with more than 10 degrees will be hard to start hot when fresh. (Hadn't heard someone talk about grounding the coil, spinning the engine, and tuning it on in years. Not a good idea with an electroic ignition though )
Re: Piston Wall Clearance [Re: Cudajon] #110396
08/26/08 06:24 PM
08/26/08 06:24 PM
ky.
K
kenworth_goose Offline
K
ky.
I think you need a mini starter. I run 16 degree base timing on all my smallblocks and have never had one of them grunt when starting hot.
Re: Piston Wall Clearance [Re: kenworth_goose] #110397
08/26/08 06:39 PM
08/26/08 06:39 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
But did your rings butt?
Re: Piston Wall Clearance [Re: moper] #110398
08/26/08 07:30 PM
08/26/08 07:30 PM
YES lets get a breaker bar on there & find out. I assumed that the retard he has is for starting rather than on the other end. I would think hard cranking at a particular initial would depend on the CR. You can ground the coil wire on an electronic ign, its cranking it with the wire open that can fry them.
Re: Piston Wall Clearance [Re: RapidRobert] #110399
08/26/08 09:55 PM
08/26/08 09:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When its hot and cranking slow unhook the MSD box and then crank it to verify if it is an over advanced ign. You have forged pistons and not hypertech pistons so then I agree the top ring gap should be .016 to .017 and the .007 Piston to wall clearence is a bit on the loose side at .007 but it will work. Will most likely be a bit noisey when cold like was said but it will be ok as it's not to tight. If you find the eng is tight and its not the ign then I would think about that .012 top ring gap you have in it. Good luck , Ron
Re: Piston Wall Clearance [Re: 383man] #110400
08/27/08 07:18 PM
08/27/08 07:18 PM
Maracaibo,Venezuela
super street
super street
Maracaibo,Venezuela
OK Gents....
Today I talked with my mechanic and he said that the first ring is .017" & second is .022".
I started and warm up the engine, then I pull out all spark plugs and turn manually and the engine is very..very hard to turn.
Maybe on this week end we pull out the engine and check everything again.
I'm thinking go to more clearance on Piston to wall, what about .010"??
Re: Piston Wall Clearance [Re: GTMaracucho] #110401
08/27/08 09:34 PM
08/27/08 09:34 PM
Maracaibo,Venezuela
super street
super street
Maracaibo,Venezuela
Re: Piston Wall Clearance [Re: GTMaracucho] #110402
08/28/08 12:06 AM
08/28/08 12:06 AM
Maracaibo,Venezuela
super street
super street
Maracaibo,Venezuela
Any Coments???
Re: Piston Wall Clearance [Re: GTMaracucho] #110403
08/28/08 12:14 AM
08/28/08 12:14 AM
Any Coments???
no mas until he gets in there & mikes everything.
Re: Piston Wall Clearance [Re: GTMaracucho] #110404
08/28/08 12:15 AM
08/28/08 12:15 AM
hemigod426 Offline
hemigod426  Offline
.010 is way to much it will rock at tdc. first i would pull pan in car to see if crank is bent or rods are binding, just a though before you pull motor and tear down
MOPAR OR NO CAR
Page 2 of 3 1 2 3
