Removing torsion bars and installing coilovers?
#1103647
10/29/11 10:27 AM
10/29/11 10:27 AM
Posts: 761 KY
juicedcuda
KY
Is it really as easy as removing the torsion bars and installing a stock location coilover in its place?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: Removing torsion bars and installing coilovers?
[Re: Gumbydammit]
#1103649
10/29/11 11:15 AM
10/29/11 11:15 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Yup, but I'd do something like this too : http://www.magnumforce.com/store/detail....rch=&Page=2 Also, I believe you need to drill and tap the lower control arm 'stud' so you can make a retainer plate.
I sure like the idea of the kit for added support, often wondered if the stock stuff would hold up under both shock and spring loads. The bottom shock mount is easy. Just spread the lower control arm for the size shock you will use. A piece of threaded rod with two nuts on it between the holes, turn them out till you have the right dimension. You may have to drill out the stock bottom shock bolt holes to 1/2, can't remember its been so long. Gumby, can you elaborate some on the stud mod?
[Re: juicedcuda]
#1103650
10/29/11 12:58 PM
10/29/11 12:58 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
It depends on the usage.The shock towers werent made to carry all the weight of the frt end.They need reinforced.Rocky
Chrysler Firepower
