Re: Street/Strip Car Street Usage
[Re: rickraw]
#1102630
10/29/11 12:32 AM
10/29/11 12:32 AM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
This I my winter work car. IMM built 408 SB with ported W2 heads 9.8 to 1 small solid roller cam, .240@.050 .630 lift victor intake 950 ultra HP. 904 trans 9.5 converter. Alum drive shaft, Moser 8 3/4 housing with alum center section with 3.73 gears {3.23s} for road trips. 275/60/15 Drag Radials. Full interior {need to install radio} heater, wipers. Manual brakes, manual steering (quick ratio box) I would not recommed it. I did the car over the summer and Iam working the bugs out trying to get it ready for its first trip (las Vegas) next month. After Vegas the plan is to get it to the track to see what it will run.
[Re: Darryls-Demon]
#1102631
10/29/11 01:19 AM
10/29/11 01:19 AM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
As stated above, there are some very nice and very quick cars on the board. I built my wife's Barracuda as a street/strip car. It's not something I would want to hop in and drive 7 hours to the Mopar Nats, but I'm sure it would make it if I had the funds for fuel. It does see a lot of street duty around the general St. Louis area though. Full steel '70 Barracuda with Gran Coupe interior, cast crank 440 with 10.4:1cr, 906 heads that flow .265 @ .600 lift, .588 Ultradyne solid cam, M1 intake, 850 AED Holley, 9.5" PTC converter, 727 w/ FWD pattern manual valve body and low band apply, 4.10 Powr Lok B-body Dana, heavy Magnum 500 wheels, 215/70s in front and 295/65 drag radials in back. Hooker Comp headers and a full TTI X-pipe exhaust. I added monoleafs, Caltracs, and adjustable Ranchos last year, but admit I have never gotten around to really messing with them since Gateway closed not too long afterwards. (I gave them some pre-load and ran it.) Not sure what the car weighs...been meaning to take it to the scales to find out. The car runs 11.50's @ 118 in full street trim including the baby seat in the back. Getting back to the suspension, it's obvious it is not optimized yet, for it only pulls a 1.68-1.78 60ft. There are a few other factors involved too...larger .960 torsion bars and regular gas shocks on the front of the car are not playing nice with the rest of the combo. I've never heard the car open exhaust and have never run it without the air cleaner. I like the fact that the car is raced in the same exact configuration as you see it on the street. Honestly, I don't want it to go any faster, for the car will never see a rollbar. ( I take that back...I want to see an 11.4x out it...I know it has it once the 60fts are where they should be.)
[Re: Blues_Cuda]
#1102632
10/29/11 03:24 AM
10/29/11 03:24 AM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
I'm trying to keep my car a street car but every time I go to the track...the tech guy disagrees with me..LOL I have owned this car since Feb 1986 I was 17 when I bought it and what a ROLLER COASTER RIDE it has been. I have 440 .040 over eagle rods JE pistons and a Low lash roller cam 585 lift 11.6 comp eddy heads tti headers victor intake 1000 hp re worked by (Cubic) a 904 w/ a 8" ati a dana 60 w/3.90 gears. My best pass was 10.67 @ 125 w/o cage and it had a race exhaust & 4.10 spool 8 3/4. 2yrs ago I put the full exhaust on a 3.73 sure grip and went 10.67 @ 123 1.45 60' Now I have a cage and a DANA and it slowed to 10.82 @ 122 ...But I drive it when its nice out, my goal now is drive it to the track reset tire pressure run a 10...what ever and drive home
[Re: StealthWedge67]
#1102633
10/29/11 09:18 AM
10/29/11 09:18 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
That is freaking AWSOME!!!! How the H--L did you get such outstanding power at such a low RPM??? Please share
Russ's last name is Dudek....... So it's in his blood. I think god blessed those Dudek boys with a 2-second advantage at birth. Seems everything they touch is at least 2 ticks faster than it should be by everyone elses standards.
I was actually born and raised in the Detroit area, but no relation to Dave. It is simply amazing how often when talking to vendors or professional equipment/service providers in the sport they would say to me…”hey, you related to Dave?” I’m sure Dave gets that all the time too.
It's 500ci with E heads according to the signature, but more info on the combo would sure be appreciated
There is nothing special about this motor or car. I spend a lot of time on the details of the build, tuning and track time.
Short block: 4.25" arm, 7.10 rod, 4.360" dia/1.49 CH Diamond piston. Zeroish deck, 10.7-10.8 CR. Well massaged high pressure standard rotor oil pump, 1/2" PU, scraper, std stroke windage tray, and Hemi oil pan. Stud kit and .25" girdle. Full time unrestricted rocker oiling and selected main oil passages enlarged. Relieved the block for valve clearance.
Heads: Mopar (Eddy) MCH CNC std. port and valves. Isky 9315 springs. 90cc chambers.
Valve train: Comp custom solid roller (Dwyane Porter) w/ "lollypop" lobes, bushed ProMagnums, Isky rollers.
General Stuff: 440-2D intake, aftermarket 950 HP Holley, exhaust port window opened up on manifolds, 2.5 TTI w/ UltraFlos. 1800 rpm converter, CRT full auto street tranny with steel drum. Battery in trunk. Wilwood front disc brakes. Mopar distributor w/ MSD 6A.
And, you don't need a roller cam to get this power level. This cam is very mild. Wayne has gone faster, and Tony quicker with similar manifold builds using solid flat tappet cams.
The car's best 60 ft is 1.87 sec. Obviously no secret supension stuff going on here.
http://508charger.yolasite.com/
[Re: BSB67]
#1102634
10/29/11 10:41 AM
10/29/11 10:41 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
The MCH ported heads and Porter camshaft are the pieces that stand out slightly (JMO) but your tuning skills have got alot to do with it as well. Great job with it Dwayne also hooked me up with a nice grind using the .420 endurance lobe design. Runs great.
Rich H.
Esse Quam Videri
[Re: BSB67]
#1102635
10/29/11 10:52 AM
10/29/11 10:52 AM
Posts: 518 ny
greenmcode
ny
I drive my Road Runner a few hundred miles a season plus 60 or so runs at the track.. The car is show room correct not on a diet in anyway 3920 with me in the car and a mild 440 6bbl.. Best et to date 11.74@117.05 1.74 60' on bias ply tire..
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
[Re: BSB67]
#1102640
10/29/11 12:42 PM
10/29/11 12:42 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
"BSB67" I have always been impressed with your combo. Definetly a cool sleeper. I also have my heads worked and my cam speced by Dwayne Porter. Everytime I see a car that Dwayne has done work to the car always run real good. That one of the reasons I used Dwaynes head and cam service and they work great. Is the 440-2 a dual plane intake as I seem to have forgot without looking it up ? "Greenmcode" I really like your Roadrunner alot. Thats one of if not my favorite color combo on a 69 Runner. If I ever have enough money to buy more Mopars a 69-1/2 six pack Runner would be top on my list as I really like the 69-1/2 six pack runners and yours looks great ! Ron
[Re: 383man]
#1102641
10/29/11 01:31 PM
10/29/11 01:31 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I drive my car to work every day for 8 months of the year. I run it at the drag strip exactly as I drive it there, no slicks or drag radials. Runs consistent low 12's with a best of 11.98 @ 117.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: BSB67]
#1102642
10/29/11 03:41 PM
10/29/11 03:41 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Our times are close, it would be a cool race. Last time out I ran 1.84 11.61 @ 121.8. Why do you run the stock convertor?
[Re: BSB67]
#1102645
10/29/11 04:24 PM
10/29/11 04:24 PM
RemCharger
Sk. Canada
Yea, I would think with a 4500 8" ati or similar, you'd be around 11.20s? Then you might be looking into some "secret suspension" stuff. Mines done caveman style,,, Big heads, cam, high rpm. Not much of street motor, But if I could afford the 13 bucks a gallon all day, I'd get some ice cream with it for sure.
[Re: 340_Dart]
#1102647
10/29/11 07:17 PM
10/29/11 07:17 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
My Dart "street car" has been 11.20s @ 119mph exactly how i drive it on the street. Air cleaner and all...
9.8:1 416 with W2's Edelbrock victor intake .570" flat tappet solid cam 727 with 4200 converter 4.10 gears 255/60/15 MT drag radials
Car weighs 3350 w/ me in it.
And thats exactly where your Dart should be- on the street! a car as nice as yours needs to be out there to be seen and enjoyed by all!
[Re: 72demon416]
#1102648
10/30/11 01:33 AM
10/30/11 01:33 AM
383man
Balt. Md
Allmost forgot about my boys Dart. It is a street car and he can drive it anywhere. Pump gas 400 in his 72 Dart. Stock stroke 400 that has .030 over KB pistons (406 cubes) Crank and rods are stock MP .557 cam Eddy RPM heads Eddy Performer RPM intake with a 750 DP Stock electronic dist I worked and MSD box CPPA 2" headers and 3" exh 727 with manual v/b and Dynamic 9.5 converter 3.91 gears and he uses 26 x 9.5 Hoosier QTP tires Weighs 3550 with him in the car Full interior all stock body Stock suspension with SS springs and 90/10 shocks up front. Driven to the track the same as me. Best et 11.45 @ 117 , Ron
[Re: 383man]
#1102649
10/30/11 02:38 AM
10/30/11 02:38 AM
Posts: 791 Bama
Randy..
Bama
well after my last toy 95 Dakota 5.9 5spd 3.91s big cam headers big injectors bla bla bla, it ran 8.12 in the 1/8 granny shifting the stock NV at 5100, cam was good to 6200, had a blast driving it and won't own another hot rod with a loose TQ and deep gears, my Valiant will have 3.54s a tight 9.5 converter and 9.0 440 with a pair of 76mm turbos, set at 10/12 lb [image]http:// [/image] s of boost, and gonna drive the crap out of it.
