ROCKERS GET LOOSE #1101110
10/24/11 09:02 PM
10/24/11 09:02 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
ever have problems with rockers that won't stay tight?
they are indy rockers and its never the same ones. after setting the lash it runs great but then its a crap shoot as to how long before one loosens up. engine is a 440 with a 590 cam and indy rockers.....any tips
THANKS
WAXER
Re: ROCKERS GET LOOSE [Re: QWK_ENUF] #1101111
10/24/11 09:09 PM
10/24/11 09:09 PM
Delray beach, Florida
P
Performance Only Offline
P
the best tip i can give you is to sell them to someone you don't like and put a decent set on there.
other than that, a single drop of wicking loc-tight will keep them from loosening.
machine shop owner and engine builder
Re: ROCKERS GET LOOSE [Re: Performance Only] #1101112
10/24/11 09:10 PM
10/24/11 09:10 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: ROCKERS GET LOOSE [Re: QWK_ENUF] #1101113
10/24/11 09:11 PM
10/24/11 09:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
THANKS
Are the surfaces below the lock nuts spot face nicely
so the nut lands flat on that surface
Re: ROCKERS GET LOOSE [Re: MR_P_BODY] #1101114
10/24/11 09:14 PM
10/24/11 09:14 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my Indys did the same thing until i put a nice set of Smith Bros adjusters in them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: ROCKERS GET LOOSE [Re: dusturbd340W5] #1101115
10/24/11 09:40 PM
10/24/11 09:40 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
20 years ago I started to give my wrench a decent shot with a dead blow hammer. Never had a loose one since
home of the
Sox and Martin Hemi Duster
Re: ROCKERS GET LOOSE [Re: Performance Only] #1101116
10/24/11 09:42 PM
10/24/11 09:42 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i bought some from you
Re: ROCKERS GET LOOSE [Re: QWK_ENUF] #1101117
10/24/11 09:59 PM
10/24/11 09:59 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
I've got the same problem with Hughes Rollers , took em off and put my Crane Ductiles back on.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: ROCKERS GET LOOSE [Re: QWK_ENUF] #1101118
10/24/11 10:26 PM
10/24/11 10:26 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Had a set of the Harland's work themselves loose when they were first installed Talk to Harland and they say to torque them to 25ft lbs the problem was solve seems there instructions say to hand tighten there instruction has not been updated sense 05.
Re: ROCKERS GET LOOSE [Re: Performance Only] #1101119
10/24/11 11:21 PM
10/24/11 11:21 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Sell them to me....I wanna sell them to DRAM.....
RIP Monte Smith
Re: ROCKERS GET LOOSE [Re: CompWedgeEngines] #1101120
10/24/11 11:32 PM
10/24/11 11:32 PM
P
P
listen pipsqueek, pipe down or i'll be paying you a visit.
Re: ROCKERS GET LOOSE [Re: Performance Only] #1101121
10/24/11 11:48 PM
10/24/11 11:48 PM
Funny thing...I do alot of different type engines and the Import stuff is amazing! You set the adjusters and they tighten up like a bank vault and WILL NOT MOVE--I am told it has something to do with the metric pitch threads--If I ever prove that I am going to try it on a Mopar rocker somehow--Every Mopar aluminum rocker I have seen with the "get loose " problem seems to have been overtightened at some point and has streached the threads in the rocker--that and China adjusters are doomsday! Smith Bros adjusters are some of the best but there is no way to beat Harland rockers on a Mopar unless you go to TD or Jesel--It is crazy to race a Mopar with anything else--it will always bite you and cost MORE than good stuff at the start IMO
Re: ROCKERS GET LOOSE [Re: Performance Only] #1101122
10/25/11 04:20 AM
10/25/11 04:20 AM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
"sell them to someone you don't like"
quoted by a engine builder,, Gezzzzzz
Re: ROCKERS GET LOOSE [Re: MAVERICKSHEMI] #1101123
10/25/11 01:45 PM
10/25/11 01:45 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
I run a Comp...solid flat tappet,.620 lift..262/266 @ .050 duration,with 1.6 Crane Ductile rockers,bronze-bushed and gone through by RAS. Isky 8005A springs,145/345 psi. My adjustments stay rock-solid,after initial settings in the Spring. If..and when I ever go to a solid roller..it's either Harland Sharp's or T&D!
Re: ROCKERS GET LOOSE [Re: a493demon] #1101124
10/25/11 02:11 PM
10/25/11 02:11 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
He must not like you
Re: ROCKERS GET LOOSE [Re: JohnRR] #1101125
10/25/11 02:29 PM
10/25/11 02:29 PM
P
P
you bought Indy rockers from me? how long ago was that?
Re: ROCKERS GET LOOSE [Re: Performance Only] #1101126
10/25/11 06:13 PM
10/25/11 06:13 PM
a493demon Offline
a493demon  Offline
a year or 2 ago.i messed up a few and todd called you and you had some.brad
Re: ROCKERS GET LOOSE [Re: a493demon] #1101127
10/25/11 06:24 PM
10/25/11 06:24 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Call Dove, they make em, and like Dan said, They arent the best. I have a set on a 440, and a set on a 340 from Hughes, but they are very light duty hydraulic cams. My Demon has Harlan Sharp, and if, IF I ever have any issues, Ill step up to T&Ds or Jessel.
kasey
Re: ROCKERS GET LOOSE [Re: QWK_ENUF] #1101128
10/25/11 08:28 PM
10/25/11 08:28 PM
fresno ca
mikeysmopars Offline
fresno ca
Ditch em and save yourself a lot of anguish.For the money Harland Sharp is great and will at least talk to you if you have an issue.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: ROCKERS GET LOOSE [Re: mikeysmopars] #1101129
10/25/11 08:44 PM
10/25/11 08:44 PM
Guitar Jones Offline
I can hear some valvetrain noise over the exhaust on my car at idle in the garage, standing next to it with the front end off but if I hear something over the exhaust at WOT it's already too late.
