ROCKERS GET LOOSE
#1101110
10/24/11 09:02 PM
10/24/11 09:02 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
ever have problems with rockers that won't stay tight?
they are indy rockers and its never the same ones. after setting the lash it runs great but then its a crap shoot as to how long before one loosens up. engine is a 440 with a 590 cam and indy rockers.....any tips
THANKS
WAXER
Re: ROCKERS GET LOOSE
[Re: QWK_ENUF]
#1101111
10/24/11 09:09 PM
10/24/11 09:09 PM
Posts: 2,091 Delray beach, Florida
Performance Only
the best tip i can give you is to sell them to someone you don't like and put a decent set on there. other than that, a single drop of wicking loc-tight will keep them from loosening.
machine shop owner and engine builder
[Re: Performance Only]
#1101112
10/24/11 09:10 PM
10/24/11 09:10 PM
Challenger 1
Cincinnati, Ohio
[Re: QWK_ENUF]
#1101113
10/24/11 09:11 PM
10/24/11 09:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
THANKS
Are the surfaces below the lock nuts spot face nicely so the nut lands flat on that surface
[Re: MR_P_BODY]
#1101114
10/24/11 09:14 PM
10/24/11 09:14 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my Indys did the same thing until i put a nice set of Smith Bros adjusters in them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1101115
10/24/11 09:40 PM
10/24/11 09:40 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
20 years ago I started to give my wrench a decent shot with a dead blow hammer. Never had a loose one since
home of the Sox and Martin Hemi Duster
#1101116
10/24/11 09:42 PM
10/24/11 09:42 PM
Posts: 1,553 baldwinsville new york
a493demon
i bought some from you
[Re: QWK_ENUF]
#1101118
10/24/11 10:26 PM
10/24/11 10:26 PM
Posts: 4,078 Mo.
racerx
Mo.
Had a set of the Harland's work themselves loose when they were first installed Talk to Harland and they say to torque them to 25ft lbs the problem was solve seems there instructions say to hand tighten there instruction has not been updated sense 05.
#1101119
10/24/11 11:21 PM
10/24/11 11:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Sell them to me....I wanna sell them to DRAM.....
RIP Monte Smith
#1101121
10/24/11 11:48 PM
10/24/11 11:48 PM
Funny thing...I do alot of different type engines and the Import stuff is amazing! You set the adjusters and they tighten up like a bank vault and WILL NOT MOVE--I am told it has something to do with the metric pitch threads--If I ever prove that I am going to try it on a Mopar rocker somehow--Every Mopar aluminum rocker I have seen with the "get loose " problem seems to have been overtightened at some point and has streached the threads in the rocker--that and China adjusters are doomsday! Smith Bros adjusters are some of the best but there is no way to beat Harland rockers on a Mopar unless you go to TD or Jesel--It is crazy to race a Mopar with anything else--it will always bite you and cost MORE than good stuff at the start IMO
#1101122
10/25/11 04:20 AM
10/25/11 04:20 AM
Posts: 370 NASHVILLE
MAVERICKSHEMI
NASHVILLE
"sell them to someone you don't like"
quoted by a engine builder,, Gezzzzzz
[Re: a493demon]
#1101124
10/25/11 02:11 PM
10/25/11 02:11 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
He must not like you
[Re: a493demon]
#1101127
10/25/11 06:24 PM
10/25/11 06:24 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Call Dove, they make em, and like Dan said, They arent the best. I have a set on a 440, and a set on a 340 from Hughes, but they are very light duty hydraulic cams. My Demon has Harlan Sharp, and if, IF I ever have any issues, Ill step up to T&Ds or Jessel.
kasey
[Re: mikeysmopars]
#1101129
10/25/11 08:44 PM
10/25/11 08:44 PM
Posts: 20,674 in a cattle trailer down by th...
Guitar Jones
Ditch em and save yourself a lot of anguish.For the money Harland Sharp is great and will at least talk to you if you have an issue.
I can hear some valvetrain noise over the exhaust on my car at idle in the garage, standing next to it with the front end off but if I hear something over the exhaust at WOT it's already too late.
