Page 3 of 3 1 2 3
Re: 2011 W8 engine masters engine in car. update [Re: deaks] #1099980
11/06/11 04:03 PM
11/06/11 04:03 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
olny change was I put the bigger of the 2 cams I tested with. 255at .050" vs the 262at .050" thats in it now. was about 30 peek HP better but 50lbs tq less at the lower RPM. the engine is not set on kill yet cam is in at 108 made more power at 104 and IG timing at 28* made best power at 30* on dyno. The carb is just as it was pulled off dyno from engine masters. Dale at CFM will need to get it back over winter set it back up for drag car.
Re: 2011 W8 engine masters engine in car. update [Re: W5DART66] #1099981
11/06/11 04:56 PM
11/06/11 04:56 PM
Finland
mafo Offline
mafo  Offline
Finland
That is impressive, I remember the trouble we had to get those numbers...you make it look easy
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: 2011 W8 engine masters engine in car. update [Re: mafo] #1099982
11/06/11 08:42 PM
11/06/11 08:42 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
nice job Brett
Re: 2011 W8 engine masters engine in car. [Re: fishy340] #1099983
11/06/11 09:00 PM
11/06/11 09:00 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i changed my mind,i think teens are in it,when she hooks..o by the way my friend has the same exact ride except his is low tens type
repost! nice job holmes
Re: 2011 W8 engine masters engine in car. [Re: fishy340] #1099984
11/06/11 09:38 PM
11/06/11 09:38 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Glad to see the car is working for you Brett. 8's are right around the corner
Re: 2011 W8 engine masters engine in car. [Re: fishy340] #1099985
11/06/11 09:52 PM
11/06/11 09:52 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Thanks guys been long road and more to go.
But this deal has been about my CNC port for update of W8 heads looks like they are working.
Hope to do drag race cam over the winter and it picks it up what I think/want it to. This is the largest CI engine I have ever done for me/my car.
Before this most of my engines were 365 CI or less so this 411 CI is large for me but small in the world of stroker small blocks.
Need to get some more updated heads on other engines.
Brett Miller
Re: 2011 W8 engine masters engine in car. [Re: W5DART66] #1099986
11/07/11 11:00 AM
11/07/11 11:00 AM
Out West
408strokerdart Offline
Out West
Outstanding Brett! I knew it was going to run good, but that is hauling. I am getting ready to pull my engine and the heads will be coming your way for the update.
Re: 2011 W8 engine masters engine in car. [Re: 408strokerdart] #1099987
11/07/11 05:27 PM
11/07/11 05:27 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
That sounds like an awesome idea!
Re: 2011 W8 engine masters engine in car. [Re: 340_Dart] #1099988
11/08/11 01:55 AM
11/08/11 01:55 AM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
would like to see what that would run with a sheet metal intake....if you wanna try one, let me know.
Re: 2011 W8 engine masters engine in car. [Re: mrsmallblock] #1099989
11/11/11 01:40 AM
11/11/11 01:40 AM
Dillsburg PA
airflowdevelop Offline
Dillsburg PA
Dang... Free sheet metal manifolds in Dillsburg to try??? I wish I knew about this!
Re: 2011 W8 engine masters engine in car. [Re: airflowdevelop] #1099990
11/11/11 12:52 PM
11/11/11 12:52 PM
Dillsburg, PA
Dillsburg, PA
Yeah, i have a CFE sheet metal intake for my w8s that we tried on the dyno when we did my motor. It has bigger ports than my colemans but i think they would match brett's bigger port opening perfectly he said.
Howard
Re: 2011 W8 engine masters engine in car. [Re: mrsmallblock] #1099991
11/15/11 11:39 PM
11/15/11 11:39 PM
Manassas, VA USA
Scamp451 Offline
Scamp451  Offline
Manassas, VA USA
Nice numbers dude!
Page 3 of 3 1 2 3
