Re: 2011 W8 engine masters engine in car.
[Re: tubtar]
#1099942
10/23/11 02:31 PM
10/23/11 02:31 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Nice, It's got a lot more in it!
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: DragDart360]
#1099943
10/23/11 03:12 PM
10/23/11 03:12 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I give up. Uninstalled Adobe old version. Installed version 11 and it still will not work for me.
So how did the engine go as far as engine master challenge?
Leon
[Re: rickstershemi]
#1099946
10/23/11 04:22 PM
10/23/11 04:22 PM
Posts: 5,160 Texas
dannysbee
Texas
I think it will go 9.50's with some traction.
Getting old just means you were smarter than some and luckier than others.
[Re: W5DART66]
#1099948
10/23/11 04:47 PM
10/23/11 04:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Should go much faster than 9.50 I have more video I will try to post tonight. I think it will go 9.teens with the small cam that's in it. Look at when it's in 3rd gear 330' out I could not use 1st at all and was spinning in 2nd so I just short shifted into drive.
I think it'll run a 9.30 unless you pick up some pretty good mph
[Re: MR_P_BODY]
#1099949
10/23/11 06:01 PM
10/23/11 06:01 PM
Posts: 5,160 Texas
dannysbee
Texas
The calculator said a 9.27 in a perfect run with your mph. I was figuring 9.50's on your first outing figuring you probably will not make that perfect run first time out. Did you make another pass? How fast did you go? Sounds awesome.
[Re: Hot 340]
#1099955
10/23/11 10:41 PM
10/23/11 10:41 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Sounds sweet, hope you get the 60' figured out.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Wicked49670dart]
#1099957
10/24/11 07:29 AM
10/24/11 07:29 AM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#1099958
10/24/11 09:42 AM
10/24/11 09:42 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
boy..do I stand corrected... I love the early Darts...I had a 64 Dart GT back in 68 w/a slant 225 and 3 on the tree...those cars were so light and hook up on stock springs... I was eating 442's and such on the street going stop light to stop light...they just couldnt believe it had only 6 cylinders...LOL yours is just awesome...
[Re: AndyF]
#1099962
10/24/11 03:03 PM
10/24/11 03:03 PM
Guitar Jones
Looks the guy in his father's Oldsmobile in the other lane pooped his pants went you hit the loud pedal. Very nice, can't wait to hear what it runs once you get the car to hook.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: S/ST 3040]
#1099967
10/25/11 12:16 AM
10/25/11 12:16 AM
Posts: 3,695 nc
emarine01
nc
I went back and watched them again, with some VOLUME.
You "double-bulbed"
.......and name the videos.
Bulbed... I dont think thats a real word Vic....
Re: 2011 W8 engine masters engine in car. update
[Re: W5DART66]
#1099981
11/06/11 04:56 PM
11/06/11 04:56 PM
Posts: 1,019 Finland
mafo
Finland
That is impressive, I remember the trouble we had to get those numbers...you make it look easy
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: fishy340]
#1099983
11/06/11 09:00 PM
11/06/11 09:00 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
i changed my mind,i think teens are in it,when she hooks..o by the way my friend has the same exact ride except his is low tens type
repost! nice job holmes
[Re: fishy340]
#1099985
11/06/11 09:52 PM
11/06/11 09:52 PM
Posts: 1,784 PA
W5DART66
PA
Thanks guys been long road and more to go. But this deal has been about my CNC port for update of W8 heads looks like they are working. Hope to do drag race cam over the winter and it picks it up what I think/want it to. This is the largest CI engine I have ever done for me/my car. Before this most of my engines were 365 CI or less so this 411 CI is large for me but small in the world of stroker small blocks. Need to get some more updated heads on other engines. Brett Miller
[Re: 408strokerdart]
#1099987
11/07/11 05:27 PM
11/07/11 05:27 PM
Posts: 1,745 Maryland
340_Dart
Maryland
Outstanding Brett! I knew it was going to run good, but that is hauling. I am getting ready to pull my engine and the heads will be coming your way for the update.
That sounds like an awesome idea!
[Re: mrsmallblock]
#1099989
11/11/11 01:40 AM
11/11/11 01:40 AM
Posts: 4 Dillsburg PA
airflowdevelop
Dillsburg PA
would like to see what that would run with a sheet metal intake....if you wanna try one, let me know.
Dang... Free sheet metal manifolds in Dillsburg to try??? I wish I knew about this!
