Re: lexan
[Re: Super Scamp]
#1099801
10/23/11 10:37 AM
10/23/11 10:37 AM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
Question: If you were to add weight to your car where would it be the most benefit? Answer: Above the rear wheels as high as possible. (rear window) Just my ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: lexan
[Re: AAR-B4]
#1099802
10/23/11 11:04 AM
10/23/11 11:04 AM
Posts: 3,210 robin hood country
deaks
robin hood country
All fine and good but there's only so many places you can take it from the front. I am thinking of putting lexan in the back and maybe a lightweight battery and glass trunk lid. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: lexan
[Re: AAR-B4]
#1099805
10/23/11 12:49 PM
10/23/11 12:49 PM
Posts: 151 ohio
Rich970
ohio
Just saying, consider the cost and effort. Building horsepower might be the better option.
i thought loosing weight was the cheapest was to go guicker ? .010 per 100 lbs
Re: lexan
[Re: Rich970]
#1099806
10/23/11 12:52 PM
10/23/11 12:52 PM
deaks
robin hood country
And it's easier on the drivetrain. This is a mod i'm looking to do, so i'll give it a bump. Mick
Re: lexan
[Re: Rich970]
#1099807
10/23/11 01:06 PM
10/23/11 01:06 PM
Posts: 9,882 MI, usa
dvw
MI, usa
ok so whats the cost ? how hard are they to install ?
I use the factory glass as a template. Buy a 4'x8' sheet and cut them out with a saber saw. Install just like the factory windows. You can make the rear side windows and fix them in position. Get rid of the regulators,more weight. Doug
Re: lexan
[Re: Rich970]
#1099810
10/23/11 01:31 PM
10/23/11 01:31 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
Just offering a suggestion, do what you want. I reinstalled the glass on my Cuda because the lexan install job was bad and it was scratched. Didn't lose any et.
Re: lexan
[Re: Stanton]
#1099813
10/23/11 03:40 PM
10/23/11 03:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If I'm not mistaken, there are some pretty good cuves in that rear glass. That will be really tough to duplicate with lexan. Anything thicker than 1/8" likely won't take the bend cold and if you heat it enough to shape it will develop air bubbles in it and look like hell. 1/8" is probably too thin and will blow out.
I've bent 1/4" with no issues what so ever... if you get air bubbles you are heating it WAY TO FAST... I have watched the guys in the plastic shop at work heat 4'X 8' sheets up to 1/2" and turned out perfect ![](/ubbthreads/images/graemlins/wave.gif)
Re: lexan
[Re: Mopar-Al]
#1099815
10/23/11 05:54 PM
10/23/11 05:54 PM
deaks
robin hood country
I see you've used the original rubber, did you heat it to make it fit. Ted I reckon my car is around 3000# + my 175. Mick
