Duster Brake Lights Are Acting Wacky
#1099536
10/22/11 10:47 PM
10/22/11 10:47 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
This is a new one to me...brake lights stay lit all the time until I step on the pedal and then they turn off! Reversed polarity? I replaced the brake light switch about a year ago.
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
Re: Duster Brake Lights Are Acting Wacky
[Re: RangerDan440]
#1099537
10/23/11 01:40 AM
10/23/11 01:40 AM
RapidRobert
As you know if the switch is tightened up too far from the point of pedal contact it'll stay permanently on just like when you step on the pedal. Not sure what's up the other way but I'm sure a visual will tell you. The bracket is slotted so you can position it so the round nub is compressed (no continuity/brake lite off) with your foot off of the pedal at rest and you want it where you move the pedal a very slight bit for continuity. The pink wire is the hot wire (just remember "hot pink") so dont inadvertently ground it & waste a fuse.
[Re: MoparMarq]
#1099539
10/23/11 10:23 AM
10/23/11 10:23 AM
RangerDan440
so should I first remove the turn signal switch to rule that out?
[Re: RangerDan440]
#1099540
10/23/11 03:20 PM
10/23/11 03:20 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I would first disconnect one of the leads on the brake pedal switch to eliminate that as a problem.
I suppose it's possible that the brake light switch has failed in some sort of manner that the switch is shorted and when the brake is applied, somehow the short is eliminated, making the brake lights go out.
With the brake light switch disconnected, check to see that the turn signals work normally, and the hazards work normally. If not, the problem is probably not the brake light switch, but somewhere downstream (turn signal switch, kick panel harness, taillight harness, ground at taillights, sockets, etc.)
My guess is that with the brake lights wacky, one or more of the turn signals are wacky, too.
You didn't make any wiring changes recently, did you?
[Re: MoparMarq]
#1099541
10/23/11 05:28 PM
10/23/11 05:28 PM
RangerDan440
I got lucky, it was the switch itself-somehow it broke off the mounting bracket and was wedged up against the top of the pedal rod so that the plunger was all the out when the pedal was not pushed in. My local Advance had one in stock and is now working fine. Thanks for the help though, now I'll know what to look for if my lights ever go nuts like that
