Re: Using OEM steel shim head gaskets on a HEMI. is it
[Re: domingo]
#1099524
10/23/11 12:23 PM
10/23/11 12:23 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
aslong as you dont make too much power,, they are fine,, id say no issues to 800hp
the rocker gear tries to come off the head on a hami so you loose clamping load on the center 5 head bolts that go through the stands,, this will allow the head gaskets to blow if you make 800+hp,, there are ways to fix it,, but for you,,,, you should be fine
