blower gear oil/lube #1098779
10/21/11 09:28 PM
10/21/11 09:28 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
OK guys, I'm going thru my GMC blower, new bearings, seals, resurfacing the end plates, etc, etc....question is after assy/install what gear oil/lube are you guys running? and to what level are you filling the end plate?, just under the shafts?...I'm also running the rear factory blower plate, even though the bearings are sealed should I maintain an oil/lube level in the rear plate as well?...any help is much appreciated
Mike
Re: blower gear oil/lube [Re: DAYCLONA] #1098780
10/21/11 11:22 PM
10/21/11 11:22 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i believe the gear lube 90/120.as for the amount i would say 6/8ounces or 1/3 of the case.
Re: blower gear oil/lube [Re: Clanton] #1098781
10/22/11 02:19 AM
10/22/11 02:19 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Thanks for the info Mike, what about the rear factory blower end plate?, same fluid level?....or just under the shafts, that what some had told me when running the rear plate?
Mike
Re: blower gear oil/lube [Re: DAYCLONA] #1098782
10/22/11 07:22 AM
10/22/11 07:22 AM
SW WI
cudacustoms1 Offline
SW WI
I was told 75/90 till it comes out the 8' oclock bolt position on the front cover.
Re: blower gear oil/lube [Re: DAYCLONA] #1098783
10/22/11 10:13 AM
10/22/11 10:13 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
do you have a pressure relief button on the ft case?i do not add oil to the rear, do you have a pic of what you have?
Re: blower gear oil/lube [Re: Clanton] #1098784
10/22/11 11:19 PM
10/22/11 11:19 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Oil level needs to be high enough to reach the bottom of the drive gear so it will "sling" the oil around
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: blower gear oil/lube [Re: Clanton] #1098785
10/23/11 09:19 PM
10/23/11 09:19 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
No relief button, should I use one? will the pressure be that much in the front cover?...this is the type of blower case, plate. cover that I have, also have the same "smooth" style bearing plate in the rear, with sealed bearings, seals, and 3 bolt retainer plates holding the bearings in, I have a cast finned cover sealing the rear bearing plate, I know I could possibly eliminate the rear plate, and use the rear cast finned BDS plate to mount the rear bearings, but if I decide to use the factory end plate along with the BDS finned rear plate, I don't need fluid/oil in the rear bearing assy?
Thanks for any input
Mike
Re: blower gear oil/lube [Re: DAYCLONA] #1098786
10/23/11 11:37 PM
10/23/11 11:37 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
you realy should have a pressure relief valve.the blower makes heat and forces iol into the case past the front seals.
Re: blower gear oil/lube [Re: Clanton] #1098787
10/24/11 01:01 PM
10/24/11 01:01 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
OK will do Mike, Thanks for your input, Much Appreciated!
Mike
