Dupli-color engine paint question #1097282
10/18/11 09:23 PM
10/18/11 09:23 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
Ok I just sprayed some primer on my 383 and it really doesn't say how long I need to wait to start spraying the hemi orange. So how long do you usually wait for the primer to dry until you paint the engine?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Dupli-color engine paint question [Re: TX9H6E4CUDA] #1097283
10/18/11 10:01 PM
10/18/11 10:01 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
if the solvent smell is gone, it should be good to go. 12-24 hours is more than enough, if it's warm and somewhat dry where you're at. if not, find a hidden spot and touch it. if it doesnt leave your fingerprint, it's dry enough.
Re: Dupli-color engine paint question [Re: Golden-Arm] #1097284
10/18/11 10:04 PM
10/18/11 10:04 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I think I waited 30 min?
Re: Dupli-color engine paint question [Re: JoesMopar] #1097285
10/18/11 10:06 PM
10/18/11 10:06 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
Dang that looks good... I've never had a problem if I put the top coat on within an hour of the primer coat.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: Dupli-color engine paint question [Re: bschargerse] #1097286
10/18/11 10:59 PM
10/18/11 10:59 PM
minnarusta
minnarusta
Awesome I just threw three cans on this is what I got
Now im gonna wait and throw some clear on it. Thanks for the help.
Re: Dupli-color engine paint question [Re: TX9H6E4CUDA] #1097287
10/19/11 12:51 AM
10/19/11 12:51 AM
near Kansas City
igozumn Offline
igozumn  Offline
near Kansas City
If you used the Dupli-color primer, it should say on the can. Bought some the other day. If not, then
Re: Dupli-color engine paint question [Re: igozumn] #1097288
10/19/11 03:04 PM
10/19/11 03:04 PM
Central IL
70Sbird Offline
70Sbird  Offline
Central IL
I just looked at this myself, the topcoat should be applied within an hour of the primer, if not then wait something like 7 days?
I will say this, with primer on bare iron , topcoated with the "Hemi Orange" and fuly cured. that paint is tough stuff! it's supposed to have some ceramic or something in it, and it holds up very well
Re: Dupli-color engine paint question [Re: 70Sbird] #1097289
10/19/11 04:55 PM
10/19/11 04:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used Dupli-Color Hemi orange on my max wedge looking eng too. Ron
Re: Dupli-color engine paint question [Re: 383man] #1097290
10/19/11 11:37 PM
10/19/11 11:37 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
I used a 1/2 a can of gray Krylon primer and then the next day I put color on it.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Dupli-color engine paint question [Re: Troy] #1097291
10/20/11 05:22 PM
10/20/11 05:22 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
i use dthe duplicolor on my slant, it seemed to be real durable once the engine was run. i used it on my dart and gas lifted it right up, but i didnt get to run it yet. i decided not to use it again after that. i went with the eastwood ceramic engine paint and the added activator, that is supposed to make it even more durable. primed it with epoxy primer, then a couple coats of the engine paint. it looked good, but the first jet change lifted it up anywhere gas touched it. i wont use that crap again. it chips easy too.
Re: Dupli-color engine paint question [Re: JAMESDART] #1097292
10/20/11 06:17 PM
10/20/11 06:17 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Hmmm; not sure why you guys are using primer? I've never used duplicolor, but I've painted all my engines with Plastikote Engine Enamel......had gas spilling all over the intake and valve covers without any paint issues.
I usually just paint a very light coat and then follow with another 2 coats while still tacky.....never had an issue.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Dupli-color engine paint question [Re: DPelletier] #1097293
10/20/11 07:03 PM
10/20/11 07:03 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
I use primer to try and make the engine kinda all one color. If you put to much paint on an engine over time the paint cracks and lifts. I use a very light coat of primer to get the engine all one color. It make all the cast iron parts a little lighter and all the sheet metal parts a little darker so it take much less engine color to get a good color on the engine without making the paint too thick.
Look in the picture...see how many dark colors there are. It would of taken 4 cans of paint to cover that thing. After a half of can of primer it only took 2 1/2 cans to get a good thick looking color with out the heavy build up of paint.
Re: Dupli-color engine paint question [Re: Troy] #1097294
10/20/11 07:49 PM
10/20/11 07:49 PM
DPelletier Offline
DPelletier  Offline
Well, as much as that sounds logical, I've never had any crack or lift or noticed any huge difference in the color of the various engine parts (mind you, no aluminum on mine). The factory never used primer.......
Re: Dupli-color engine paint question [Re: TX9H6E4CUDA] #1097295
10/20/11 09:27 PM
10/20/11 09:27 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Most of the time you only want/need to let the solvents flash off in the paints and want to re-caot while still a slight drag to the touch, but not wet.
I never got too excited over Duplicolor, but seems their new paint may be better.
Plasticoat is what I used when I wanted a nocer gloss on a cheap paint job. I almost always spray with a single stage PPG urethane on most of my customers, as it doesnt peel or lift, stay durable and glossy forever, and cleans with just the wipe of a rag, but it aint cheap.
Attached is the Plasticoat with primer underneath.
RIP Monte Smith
Re: Dupli-color engine paint question [Re: DPelletier] #1097296
10/21/11 12:15 PM
10/21/11 12:15 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats exactly how ive done it for years,never any problem with appearance or durability.its all in the surface prep.
Re: Dupli-color engine paint question [Re: DPelletier] #1097297
10/21/11 03:34 PM
10/21/11 03:34 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
...do you realy want your engine to look "As Good" as the factory did theres.
Re: Dupli-color engine paint question [Re: Troy] #1097298
10/21/11 03:47 PM
10/21/11 03:47 PM
DPelletier Offline
DPelletier  Offline
Troy, that's a really good point and I'm not trying to criticise how you are doing it as it obviously works for ya.
OTOH, I DO actually find alot of the spray booth, base clear, hi end engine jobs to look......well, WRONG. My technique is neater than factory with better coverage, but if I get a chip or a ding in the paint, it's easy to touch up and if I don't you see the metal underneath......just like on the survivor 'Cuda sitting next to the 'Bee.
