Oil pressure how much is needed #1094947
10/15/11 02:00 PM
10/15/11 02:00 PM
SD USA
neonic Offline OP
neonic  Offline OP
SD USA
My new 582 B1 motor only runs 50# and never changes from idle to full throttle. I run a milodon dual line system with milodons pro pump. We run 20-50 Bran Penn oil. How much oil pressure is realy needed under full race conditions.
Re: Oil pressure how much is needed [Re: neonic] #1094948
10/15/11 03:26 PM
10/15/11 03:26 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i was told 10# per 1000 rpm is enough.
Re: Oil pressure how much is needed [Re: neonic] #1094949
10/15/11 06:21 PM
10/15/11 06:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Seems strange it doesnt pick up pressure as the revs
goes up...might want to check the by-pass... specially
with that thick of oil.... change the filter also...
this is of course that the gauge is working correctly
Re: Oil pressure how much is needed [Re: neonic] #1094950
10/15/11 10:51 PM
10/15/11 10:51 PM
ky
68roadrunner Offline
ky
i am with mr p on this one. i run 20w50 oil and i see a swing of 80 with rpm to about 40 hot at idle, might check you relief, and all oil filters are not compatible with alcohol.
Re: Oil pressure how much is needed [Re: 68roadrunner] #1094951
10/16/11 10:38 AM
10/16/11 10:38 AM
SD USA
neonic Offline OP
neonic  Offline OP
SD USA
Yes thats what I thought also. i have put a new bypass spring kit in and replaced the gauge. also took the pan off to make sure I was not sticking to the bottom with the pickup. I can shim the spring and gain about 10#. The oil pressure runs the same after doing this no change cold to warm and only about 57# when shimmed. We started out with a milling HV63 pump thought that was the issue so we changed to the milodon pump. Zero change in oil pressuer after doing this. So back to the original question how much oil pressuer is needed on a motor that turns 8000 rpm.
Re: Oil pressure how much is needed [Re: neonic] #1094952
10/16/11 10:46 AM
10/16/11 10:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would say 70#... like was said already.... the rule
of thumb is 10# per 1000 rpm... but remember that
pressure is a by product of flow vs restriction ...
you want flow to pull heat off... but I still would
be concerned that it doesnt increase with rpm... I
have NEVER seen a engine do what yours is doing
Re: Oil pressure how much is needed [Re: neonic] #1094953
10/16/11 10:48 AM
10/16/11 10:48 AM
Finland
mafo Offline
mafo  Offline
Finland
in my pump someone had cut the bypass spring, it had only 50 psi or so at 9000, the pump came on my Nickens motor , I didn t feel comfortable with that so now i m running 70 -75
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Oil pressure how much is needed [Re: mafo] #1094954
10/16/11 11:05 AM
10/16/11 11:05 AM
SD USA
neonic Offline OP
neonic  Offline OP
SD USA
i was thinking on the same line when I put a new spring in it. The only thing I have not changed is the bypass plate it self. I guess thats next.
Re: Oil pressure how much is needed [Re: neonic] #1094955
10/16/11 11:12 AM
10/16/11 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It sounds like the by-pass isnt closing all the way
and has a weak spring... you added a shim and it went
up slightly... with enough shims it should be able
to blow the filter apart.... are you sure all the plugs
are in the engine... I forgot 1 in the front behind
the timing cover and it did the same thing
Re: Oil pressure how much is needed [Re: MR_P_BODY] #1094956
10/16/11 12:39 PM
10/16/11 12:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW we have 62lbs in the 99 Hemi from idle to 9500, but it is a dry sump system..
Do you have pushrod oiling or tradition oiling to the rockers. What rockers and do you have restrictors?
Re: Oil pressure how much is needed [Re: Al_Alguire] #1094957
10/17/11 11:14 AM
10/17/11 11:14 AM
SD USA
neonic Offline OP
neonic  Offline OP
SD USA
push rod oiling, jesel rockers and comp 892 lifters. The push rods have restrictors and one side of the lifter is blocked off.
Re: Oil pressure how much is needed [Re: neonic] #1094958
10/17/11 11:26 AM
10/17/11 11:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With my W-5 I just finished up I run TD rockers with
PR oiling and the lifters have a axle feed on the lifters
also and when I was priming it, it had 65# when it
was spinning pretty good and 50# when the drill was
spinning about 300 rpm which would be 600 rpm at the
crank.. this was with 10W30 oil
Re: Oil pressure how much is needed [Re: neonic] #1094959
10/17/11 12:06 PM
10/17/11 12:06 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Is it oiled through the pushrods? If so, what size is the lfter bushing hole or pushrod hole? The reason I ask is to know how you are restricting the oil flow to the rockers.
Re: Oil pressure how much is needed [Re: camastomcat] #1094960
10/17/11 12:08 PM
10/17/11 12:08 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
OK I didn't read the whole post....so the restrictors need to be no more than .060.
Re: Oil pressure how much is needed [Re: rickraw] #1094961
10/17/11 12:16 PM
10/17/11 12:16 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I've heard 10# per 100 HP, too, from a former NASCAR engine builder who says it the power, not the rpm, you need to account for. Either way, I don't think 50 psi is enough for that engine.
Re: Oil pressure how much is needed [Re: camastomcat] #1094962
10/17/11 12:35 PM
10/17/11 12:35 PM
SD USA
neonic Offline OP
neonic  Offline OP
SD USA
The push rod restrictors are .080 would not think this should take a lot of oil pressure off but something is causing it to be lower then it should.
Re: Oil pressure how much is needed [Re: neonic] #1094963
10/17/11 12:46 PM
10/17/11 12:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I went with .040 restriction on my PRs ... I didnt
measure the hole in the lifters that feeds the PR so
I'm not sure if I truly needed to restrict the PRs
or not
Re: Oil pressure how much is needed [Re: neonic] #1094964
10/17/11 12:47 PM
10/17/11 12:47 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
My B1 with pushrod oiling has a .060 oil hole in the bushings (World aluminum block) and makes around 65-70 psi at 7400rpm. It does rise with rpm though. I only really have about 20#'s when the oil is hot at an idle, after a run. So....I can't say for sure that that's your issue, but it couldn't help tha situation and the oil pressure should go up with RPM.
Re: Oil pressure how much is needed [Re: neonic] #1094965
10/17/11 01:32 PM
10/17/11 01:32 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Gauge pressure isn't what the bearings get, it's only the force with which the pump refreshes the supply to the journal.
The actual local pressure is much higher, and also varies with certain other factors:
1. engine speed
2. journal diameter (actually, circumference)
3. bearing width to the closest leak
1. means local pressure goes up with RPM even if the gauge doesn't move.
2. the relative speeds of the journal and bearing surface in feet/second are what develops the oil wedge, and larger journals have higher local pressure at the same RPM. For a main bearing, it's obvious (3.000" main @ 7,000 RPM = 1,100 f/s, but a rod bearing oscillates while its journal spins so the relative speed changes quite a bit.
This is one reason why low speed truck engines have big journals: good pressure at the bearings at low RPM with low pump pressure.
This is also why it's dangerous to lug small journal motors at low RPM regardless of pump pressure.
3. for a continuous bearing surface this is obvious; however, a groove reduces the pressure to less than 50% vs. an undivided surface.
Math for the closest leak:
width 1.000"
closest leak: 50% = .500"
groove .060"
each half .470"
closest leak: 50% = .235"
Boffin Emeritus
Re: Oil pressure how much is needed [Re: polyspheric] #1094966
10/17/11 01:45 PM
10/17/11 01:45 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
1. engine speed
width 1.000"
groove .060"
each half .470"
I sort of understand what you are saying, but could you dumb it down a bit? Most on here including me aren't this technically astute.
