Re: How much power can a 8.75 rearend handle?
[Re: robnbird]
#1094462
10/23/11 10:33 AM
10/23/11 10:33 AM
Challenger 1
Cincinnati, Ohio
If I have to ask about a 8 3/4 Im not going to be very confident. better off with a 60 or a 9" ford in my oppenion.
OMG you said 9" ford on a Mopar site!!
[Re: Super Scamp]
#1094463
10/23/11 11:32 AM
10/23/11 11:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Going on 8+ years all in the 10`s at 3200lbs. and I run the 742 case w/Richmond 4.11 gears, Dutchman 30 spline axles, stock caps and a backbrace.
LUCKY...Is correct word in this post.
The time is going to come when all of you 10 second cars hook up 1 good time and the weak link is going to cause you to spend lots of to fix you Trans/rear/and maybe the motor.
You all need one of these...
I've been in the 8s with my 8 3/4... like I've said a thousand times "I think its a weight issue"... JMO
[Re: Thumperdart]
#1094466
10/23/11 12:59 PM
10/23/11 12:59 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
I ran a string of 10.70's on my 8 3/4 this year. Stock axles, stock caps stock gears and a stock cone sure grip. The car is 3400 race weight with exhaust on. HOWEVER I have a big squishy converter, and I think the 3.23 gears are saving the axles. Best 60' was a 1.55 buy most were 1.59-1.61. I plan on changing to a Dana 60 this winter. Here is a video of a 1.61 leave. It doesn't look like this set up will break anytime soon, but it's a boring launch. http://www.youtube.com/watch?v=8-PO1bCE3E0&feature=youtube_gdata_player-Kenny
[Re: Challenger 1]
#1094468
10/23/11 06:52 PM
10/23/11 06:52 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Binder Dundat.
Pooched 6 different pumpkins with different brands of brand new gears, spool, 31 spline 4 spider posis, WAR cases, nodular cases, you name it. Jamie Roth, Ian Wood, the crazy AMC guy in Mission, everybody tried to build me a third member, none lasted!
No more 9" rears for THIS guy!!!!
CrAzYMoPaRGuY
[Re: FastmOp]
#1094471
10/24/11 12:56 PM
10/24/11 12:56 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
In may I was down to eight cars and the chick I was racing went red. I had a 5.99 dial in on it when the 8&3/4 let go. It broke the trans too. So I stuck a Dana in it, now I can tranzbreaking it every pass and not worry
The last street gear I had broke the teeth on the ring gear on the final points night with 4 rounds to go. I needed one more round to win the track championship. That thing made it through 4 more passes and not only did I win the championship but I won the race too. When I pulled it apart the next day I was amazed it lasted the rest of the night. It looked like it shouldn't have made it onto the trailer.
[Re: Dap]
#1094475
10/25/11 11:07 AM
10/25/11 11:07 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
I think if you sit down with a piece of paper and cost out making the 8 3/4 stronger vs installing a Dana, you will have your answer. Either way get some good axles in that thing. BTW congrats on your promotion!
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
