Page 2 of 3 1 2 3
Re: How much power can a 8.75 rearend handle? [Re: Voluster] #1094440
10/16/11 01:14 PM
10/16/11 01:14 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the 489 center section with the crush sleeve elminator kit should be stronger than the 742?
My gripe is I priced out the cost of doing all the upgrades (yoke, gears, caps, spool, bearings, axles, and backbrace) and it was near the same cost as a new S60 rearend (and I could use my stock 8-3/4 in a different car anyhow.)
Re: How much power can a 8.75 rearend handle? [Re: 451Mopar] #1094441
10/16/11 01:28 PM
10/16/11 01:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The alum center is based off of the 742
Re: How much power can a 8.75 rearend handle? [Re: Voluster] #1094442
10/16/11 08:16 PM
10/16/11 08:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I just went 9.59 at 139 with a 1.36 60 ft last weekend with a 8 3/4 on a drag raidal
We figured 720 hp the car weighed 3460
tic, tic, tic........
Re: How much power can a 8.75 rearend handle? [Re: jcc] #1094443
10/16/11 08:31 PM
10/16/11 08:31 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Block?... convert? balancer? rod? crank? sprag? u joint? rocker? timing chain? lifter?
whats the ticking all about?
Re: How much power can a 8.75 rearend handle? [Re: Crock] #1094444
10/16/11 09:17 PM
10/16/11 09:17 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
So far mine has been fine. Alum center with a spool,footbrake at 3300lbs.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: How much power can a 8.75 rearend handle? [Re: Dap] #1094445
10/16/11 11:27 PM
10/16/11 11:27 PM
Guitar Jones Online laugh2
The 742 is the strongest as it has the largest rear pinion bearing of any passenger car rear end, including the 489. Yes the pinion shaft diameter is slighly larger at 1 7/8 than the 742 at 1 3/4 but that's already larger than the Dana 60 pinion shaft so it's a non issue. It's the size of the rear bearing that keeps pinion head deflection to a minimum.
Re: How much power can a 8.75 rearend handle? [Re: Crock] #1094446
10/16/11 11:46 PM
10/16/11 11:46 PM
tn
robnbird Offline
robnbird  Offline
tn
If I have to ask about a 8 3/4 Im not going to be very confident. better off with a 60 or a 9" ford in my oppenion.
Re: How much power can a 8.75 rearend handle? [Re: Guitar Jones] #1094447
10/22/11 03:17 AM
10/22/11 03:17 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The new Mopar Action magazine claims the 489 case has a larger pinion and bearing (and yoke splines)?
The aluminum cases are pretty expensive. I though the bare case was around $800?
Re: How much power can a 8.75 rearend handle? [Re: 451Mopar] #1094448
10/22/11 10:09 AM
10/22/11 10:09 AM
ill
dennismopar73 Offline
ill
that is correct , the 489 case is stronger, but you have top replace the crush sleeve with the bushing kit,
Re: How much power can a 8.75 rearend handle? [Re: dennismopar73] #1094449
10/22/11 10:18 AM
10/22/11 10:18 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Going on 2 years with my 8 3/4 running cosistant 10.60's with a 3800lb car! with 35 spline axles spool and back brace.
67' charger 499 RB 10.57 at 127
Re: How much power can a 8.75 rearend handle? [Re: dennismopar73] #1094450
10/22/11 01:27 PM
10/22/11 01:27 PM
That may be debatable but I don't think so. MP could have used any case they wanted to pattern their aluminum case after and they chose to use the 742. There is no debate that the 742 has the biggest rear pinion bearing and that makes it a better choice despite the pinion shaft size. Which as I pointed out earlier is a non issue.
Just how much better is a 742 though? I don't know. I'm not an engineer but I don't think it's a significant difference.
Re: How much power can a 8.75 rearend handle? [Re: Guitar Jones] #1094451
10/22/11 02:19 PM
10/22/11 02:19 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have the 742 that must be why it hasnt broke yet!
Re: How much power can a 8.75 rearend handle? [Re: dragram440] #1094452
10/22/11 03:54 PM
10/22/11 03:54 PM
MN
hemidup Offline
hemidup  Offline
MN
Just spit one out at the track today. It made it a whole whopping 3'. Hopefully the trans is still good, but doubt it.
Jerry Williams.
Re: How much power can a 8.75 rearend handle? [Re: hemidup] #1094453
10/22/11 04:45 PM
10/22/11 04:45 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
What was it in? How much power? How many passes did it last?
Re: How much power can a 8.75 rearend handle? [Re: dragram440] #1094454
10/22/11 05:54 PM
10/22/11 05:54 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Launch rpm? Stall? Aftermarket or factory R&P?? Stock caps? How heavy?
Re: How much power can a 8.75 rearend handle? [Re: Dean_Kuzluzski] #1094455
10/22/11 07:20 PM
10/22/11 07:20 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
we started twisting the stock axles splines in the 10.90's. car weighs 3400. I agree. at least buy the hardened axles. It's definitely worth it for the safety. we went to a dana.
Re: How much power can a 8.75 rearend handle? [Re: dragram440] #1094456
10/22/11 08:54 PM
10/22/11 08:54 PM
MN
hemidup Offline
hemidup  Offline
MN
489/3.91 gears. 73 Dart Sport with a 550 crank hp motor.
Jerry Williams.
Re: How much power can a 8.75 rearend handle? [Re: JACK1440] #1094457
10/22/11 09:15 PM
10/22/11 09:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My Strange axles are twisted about 3/4 of a spline right
where they come out of the spool... they've been the
same for 4 years now... not getting any worse... thats
on my alum center 8 3/4 with a back brace... 2400#
leaving at 5600 rpm on a 5600 stall with a 1.19 60'
Re: How much power can a 8.75 rearend handle? [Re: Guitar Jones] #1094458
10/22/11 09:25 PM
10/22/11 09:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The 742 design may have been MP choice because of no crush sleeve and just maybe better current gear choice. Additionally, the weakest link is always the first item to be solved in design upgrades, and I would venture to guess mopar engineers at the time of the orignal 742 thought a larger pinion shaft dia was needed, maybe for less shaft deflection under high power between the pinion and the ring, which could lead to sheared teeth. With the new alum case reportedably designed 10%? stiffer, going back to the larger bearing non crush sleeve common 742 made the most sense
To add: I don't believe bearing size of the pinion is hardly any part of deflection issues. Roller bearings hardly deflect at all until complete failure. However a pinion load is cantilevered past the rear pinion bearing, allowing for possible deflection of the pinion shaft, a design shortfall the 9" does not have.
Re: How much power can a 8.75 rearend handle? [Re: jcc] #1094459
10/22/11 10:04 PM
10/22/11 10:04 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've run 8 3/4 in my Volare forever. 11.0@122, 1.53 60, 3875lbs. The 742,4.56 went from it to Dizusters 11.90 duster,to my buddys 10.80 GTX. It's still going. 100s of passes.
Doug
Page 2 of 3 1 2 3
