Re: How much power can a 8.75 rearend handle?
[Re: Voluster]
#1094440
10/16/11 01:14 PM
10/16/11 01:14 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I think the 489 center section with the crush sleeve elminator kit should be stronger than the 742? My gripe is I priced out the cost of doing all the upgrades (yoke, gears, caps, spool, bearings, axles, and backbrace) and it was near the same cost as a new S60 rearend (and I could use my stock 8-3/4 in a different car anyhow.)
[Re: 451Mopar]
#1094441
10/16/11 01:28 PM
10/16/11 01:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The alum center is based off of the 742
[Re: Crock]
#1094444
10/16/11 09:17 PM
10/16/11 09:17 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
So far mine has been fine. Alum center with a spool,footbrake at 3300lbs.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: Dap]
#1094445
10/16/11 11:27 PM
10/16/11 11:27 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
The 742 is the strongest as it has the largest rear pinion bearing of any passenger car rear end, including the 489. Yes the pinion shaft diameter is slighly larger at 1 7/8 than the 742 at 1 3/4 but that's already larger than the Dana 60 pinion shaft so it's a non issue. It's the size of the rear bearing that keeps pinion head deflection to a minimum.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: dennismopar73]
#1094449
10/22/11 10:18 AM
10/22/11 10:18 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Going on 2 years with my 8 3/4 running cosistant 10.60's with a 3800lb car! with 35 spline axles spool and back brace.
67' charger 499 RB
10.57 at 127
[Re: dennismopar73]
#1094450
10/22/11 01:27 PM
10/22/11 01:27 PM
Guitar Jones
that is correct , the 489 case is stronger, but you have top replace the crush sleeve with the bushing kit,
That may be debatable but I don't think so. MP could have used any case they wanted to pattern their aluminum case after and they chose to use the 742. There is no debate that the 742 has the biggest rear pinion bearing and that makes it a better choice despite the pinion shaft size. Which as I pointed out earlier is a non issue.
Just how much better is a 742 though? I don't know. I'm not an engineer but I don't think it's a significant difference.
[Re: dragram440]
#1094452
10/22/11 03:54 PM
10/22/11 03:54 PM
Posts: 833 MN
hemidup
MN
Just spit one out at the track today. It made it a whole whopping 3'. Hopefully the trans is still good, but doubt it.
Jerry Williams.
[Re: JACK1440]
#1094457
10/22/11 09:15 PM
10/22/11 09:15 PM
MR_P_BODY
we started twisting the stock axles splines in the 10.90's. car weighs 3400. I agree. at least buy the hardened axles. It's definitely worth it for the safety. we went to a dana.
My Strange axles are twisted about 3/4 of a spline right where they come out of the spool... they've been the same for 4 years now... not getting any worse... thats on my alum center 8 3/4 with a back brace... 2400# leaving at 5600 rpm on a 5600 stall with a 1.19 60'
[Re: Guitar Jones]
#1094458
10/22/11 09:25 PM
10/22/11 09:25 PM
Posts: 22,696 Bitopia
jcc
Bitopia
The 742 design may have been MP choice because of no crush sleeve and just maybe better current gear choice. Additionally, the weakest link is always the first item to be solved in design upgrades, and I would venture to guess mopar engineers at the time of the orignal 742 thought a larger pinion shaft dia was needed, maybe for less shaft deflection under high power between the pinion and the ring, which could lead to sheared teeth. With the new alum case reportedably designed 10%? stiffer, going back to the larger bearing non crush sleeve common 742 made the most sense
To add: I don't believe bearing size of the pinion is hardly any part of deflection issues. Roller bearings hardly deflect at all until complete failure. However a pinion load is cantilevered past the rear pinion bearing, allowing for possible deflection of the pinion shaft, a design shortfall the 9" does not have.
[Re: jcc]
#1094459
10/22/11 10:04 PM
10/22/11 10:04 PM
Posts: 9,824 MI, usa
dvw
MI, usa
I've run 8 3/4 in my Volare forever. 11.0@122, 1.53 60, 3875lbs. The 742,4.56 went from it to Dizusters 11.90 duster,to my buddys 10.80 GTX. It's still going. 100s of passes. Doug
