Hemi Springs #109371
08/23/08 08:42 PM
08/23/08 08:42 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
which valve spring are they using on the 472 crate hemi,or where could one find all the specs on that motor. thanks
Re: Hemi Springs [Re: 426lloyd] #109372
08/24/08 12:54 AM
08/24/08 12:54 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Not sure of the exact spring but it uses a flat hydraulic, so it can't be more than 130lbs closed. I'm pretty sure mine were either a double spring or a single with a damper, but they are same physically as one would use in a 440 (1.5 diameter, around 1.84" installed height).
I'm using the heads from a 528 (aluminum-not the Eddy heads). I did notice that the retainers were out to lunch.
