Re: Pump gas friendly race motor [Re: Bigcube] #1093498
10/14/11 08:38 PM
10/14/11 08:38 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Here's what that page spits out for my current compression/cam
Your dynamic compression ratio is 11.21:1 .
Your dynamic cranking pressure is 244.55 PSI.
So it's safe to assume this WON'T run on pump gas
LOL
i know a guy a couple miles from me with an iron headed 390 and around 225 psi on pump 93.
But 244...likely not.
Re: Pump gas friendly race motor [Re: POS Dakota] #1093499
10/15/11 12:18 AM
10/15/11 12:18 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
With a dynamic CR of 11.21, I gotta ask ... what's your static CR ????
Re: Pump gas friendly race motor [Re: Stanton] #1093500
10/15/11 08:30 AM
10/15/11 08:30 AM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
It's 15:1
Re: Pump gas friendly race motor [Re: Bigcube] #1093501
10/15/11 09:53 AM
10/15/11 09:53 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It's 15:1
E85 cornfed bigcube dart maybe?
68 Barracuda Formula S 340
Re: Pump gas friendly race motor [Re: Bigcube] #1093502
10/15/11 09:59 AM
10/15/11 09:59 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
hey bigcube 11.1 ur fine w sunoco ultra or good 93 octane..mine is 11.5 i run ny garbage gas for the street with little bangin of the throttle here and there- its fine,now when i go to the track i put a gal of 110 or 116 mix with 3 gals of 93 and have no problemos
Re: Pump gas friendly race motor [Re: Bad340fish] #1093503
10/15/11 12:46 PM
10/15/11 12:46 PM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
It's 15:1
If they had it around here I'd consider it. But I really want to tame it down some and drive the car more. I've always ran VP C-16 in it.
Re: Pump gas friendly race motor [Re: Bigcube] #1093504
10/15/11 01:55 PM
10/15/11 01:55 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
My PRH 572 is right at 10.75:1 and runs fine on 93UL pump swill. Cam is a 266/272 110lsa Comp Roller. The engine idles nice at 1050rpm and is easy to drive on the street
Ron
Re: Pump gas friendly race motor [Re: firefighter3931] #1093505
10/15/11 03:38 PM
10/15/11 03:38 PM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
What heads? Did Dwayne dyno it? It would be a good comparison because mine was run on his dyno.
Re: Pump gas friendly race motor [Re: Bigcube] #1093506
10/15/11 03:45 PM
10/15/11 03:45 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
jim i look forward to seeing the car out again.people need to see your car in person,to appreciate the detail you have gone too in the car,beautiful and fast,and you have not cracked the fogger yet,good luck and see you in the spring time mike d.
Re: Pump gas friendly race motor [Re: Bigcube] #1093507
10/16/11 09:15 AM
10/16/11 09:15 AM
Ontario,Canada
Ontario,Canada
Jim, the heads are EZ 295's with some massaging by Dwayne
Here's a thread on the build with dyno numbers using different manifold/carb combos :
https://board.moparts.org/ubbthreads/show...e=0#Post5622009
Ron
Re: Pump gas friendly race motor [Re: Bigcube] #1093508
10/16/11 09:24 AM
10/16/11 09:24 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Firefighter you ever run that at the track?
Mopar Performance
Re: Pump gas friendly race motor [Re: Bigcube] #1093509
10/16/11 09:28 AM
10/16/11 09:28 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It's 15:1
Its kind of available around here but not everywhere. I have considered sourcing it in a drum if I decide to go that route. Its easier to avoid all those gas station stories about the 383 six pack hemis anyways lol.
Re: Pump gas friendly race motor [Re: firefighter3931] #1093510
10/16/11 11:00 AM
10/16/11 11:00 AM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
Ron
Very nice, Dwaynes the MAN!
Re: Pump gas friendly race motor [Re: firefighter3931] #1093511
10/16/11 01:33 PM
10/16/11 01:33 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Ron
looking great there ron. but i have a question for you.on the mopar 337 intake.did you use it to cover up the valley? i mean did you use it instead of useing the indy valley plate or did the intake bolt on top of the indy plate? sorry for the weared question.but in the pic the 337 intake almost looks like it is bolted on top of the indy valley plate? i might be wanting to try this intake latter on down the road.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Pump gas friendly race motor [Re: mopar65] #1093512
10/16/11 02:36 PM
10/16/11 02:36 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If you replace your current headgaskit with something like a thick copper one and gain .080 or so where would your compression be?
I'd run as much stuff as I could if I had what you have sitting around. That thing is fresh so I'd really look at doing as little and as cheep as I could. Pistons would be as far as I would go. Then you could spend the cash saved for 110 or E85
I would stick exhaust with electric cut-outs on it. Cause you know "ice cream is better with open headers".
Re: Pump gas friendly race motor [Re: moparniac] #1093513
10/16/11 05:32 PM
10/16/11 05:32 PM
Ontario,Canada
Ontario,Canada
Yep, been trying to work out all the gremlins ; fuel delivery and the Tq converter been giving me grief !
The car is also real heavy (4200 lbs raceweight) so i'm making some off season changes to lighten things up.
Ron
Re: Pump gas friendly race motor [Re: mopar65] #1093514
10/16/11 05:35 PM
10/16/11 05:35 PM
Ontario,Canada
Ontario,Canada
Bobby, with the raised port EZ heads we had to install an Indy valley cover underneath the 337 manifold. Good eye !
Ron
Re: Pump gas friendly race motor [Re: firefighter3931] #1093515
10/16/11 07:47 PM
10/16/11 07:47 PM
texas
moparman63 Offline
moparman63  Offline
texas
my 499 low deck is 11.1:1 with 175psi cranking.it lives great on 90 octane.even with 150hp nitrous and 36 degrees timing.i believe camshaft and rpm are where its at.mine has sr head,a torque monster cam and 5700rpm shift point.i dont spray it anymore but i did for the firzt 10 years of its life.
Re: Pump gas friendly race motor [Re: Bigcube] #1093516
10/16/11 11:28 PM
10/16/11 11:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Jim,
some pistons, rods, a cam, and a set of valve springs and you'd be right in pump gas/grocery getter heaven
