Re: Pump gas friendly race motor
[Re: Bigcube]
#1093498
10/14/11 08:38 PM
10/14/11 08:38 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Here's what that page spits out for my current compression/cam
Your dynamic compression ratio is 11.21:1 . Your dynamic cranking pressure is 244.55 PSI.
So it's safe to assume this WON'T run on pump gas
LOL
i know a guy a couple miles from me with an iron headed 390 and around 225 psi on pump 93.
But 244...likely not.
[Re: POS Dakota]
#1093499
10/15/11 12:18 AM
10/15/11 12:18 AM
Posts: 8,862 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
With a dynamic CR of 11.21, I gotta ask ... what's your static CR ????
[Re: Bad340fish]
#1093503
10/15/11 12:46 PM
10/15/11 12:46 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
It's 15:1
E85 cornfed bigcube dart maybe?
If they had it around here I'd consider it. But I really want to tame it down some and drive the car more. I've always ran VP C-16 in it.
[Re: Bigcube]
#1093506
10/15/11 03:45 PM
10/15/11 03:45 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
jim i look forward to seeing the car out again.people need to see your car in person,to appreciate the detail you have gone too in the car,beautiful and fast,and you have not cracked the fogger yet,good luck and see you in the spring time mike d.
[Re: Bigcube]
#1093508
10/16/11 09:24 AM
10/16/11 09:24 AM
Posts: 6,295 U.S.
moparniac
U.S.
Firefighter you ever run that at the track?
Mopar Performance
[Re: mopar65]
#1093512
10/16/11 02:36 PM
10/16/11 02:36 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
If you replace your current headgaskit with something like a thick copper one and gain .080 or so where would your compression be? I'd run as much stuff as I could if I had what you have sitting around. That thing is fresh so I'd really look at doing as little and as cheep as I could. Pistons would be as far as I would go. Then you could spend the cash saved for 110 or E85 I would stick exhaust with electric cut-outs on it. Cause you know "ice cream is better with open headers".
[Re: moparniac]
#1093513
10/16/11 05:32 PM
10/16/11 05:32 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Yep, been trying to work out all the gremlins ; fuel delivery and the Tq converter been giving me grief !
The car is also real heavy (4200 lbs raceweight) so i'm making some off season changes to lighten things up.
Ron
[Re: mopar65]
#1093514
10/16/11 05:35 PM
10/16/11 05:35 PM
firefighter3931
Ontario,Canada
looking great there ron. but i have a question for you.on the mopar 337 intake.did you use it to cover up the valley? i mean did you use it instead of useing the indy valley plate or did the intake bolt on top of the indy plate? sorry for the weared question.but in the pic the 337 intake almost looks like it is bolted on top of the indy valley plate? i might be wanting to try this intake latter on down the road.thanks Mopar65
Bobby, with the raised port EZ heads we had to install an Indy valley cover underneath the 337 manifold. Good eye !
Ron
[Re: Bigcube]
#1093516
10/16/11 11:28 PM
10/16/11 11:28 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Jim, some pistons, rods, a cam, and a set of valve springs and you'd be right in pump gas/grocery getter heaven
