AC Heater control Bracket #1092782
10/11/11 04:19 PM
10/11/11 04:19 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
Hey Guys,
I just bought a year one repro heater control valve for a 70 challenger to get the heater operational in an a/c car... but the bracket doesn't come with it.
Does anyone know if the year one style valve (all metal, pic attached) will work with an original style bracket ?
I don't want to go out and buy a bracket to find out it only works with the original bakelight style control valve...
Thanks, Shawn
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: AC Heater control Bracket [Re: smac77] #1092783
10/12/11 01:36 PM
10/12/11 01:36 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
I was missing both the water valve and bracket for my project, i found a 318 parts car complete with bracket and a metal valve, later on I tracked down a bakelite valve and the bracket bolts up to both, so you should be good to go.
Re: AC Heater control Bracket [Re: EV2RTSE] #1092784
10/13/11 03:43 PM
10/13/11 03:43 PM
None
71rm23 Offline
71rm23  Offline
None
Might try Bill Rolick. He's a member here. i bought one at the Mopar Nats for my Heater controler but it was different than whats pictured. Mine has a vacuum line that attaches to it. If I remember right, isnt the one pictured for the cable operated?
Anyway, I'd try him
