Air Temp Sensor in Air Cleaner #1092711
10/11/11 02:36 PM
10/11/11 02:36 PM
middle of the country
aar1 Offline OP
aar1  Offline OP
I need to find the Temp Sensor that goes inside a 1970 dual snorkel air cleaner housing. Any thoughts on where to fine one at a reasonable price. I think the part number is 3514168.
Thanks!
Re: Air Temp Sensor in Air Cleaner [Re: aar1] #1092712
10/11/11 02:58 PM
10/11/11 02:58 PM
MoreParts Offline
MoreParts  Offline
I don't know the interchange on that, but I'd suspect a lot of 1970 junkyarders use the same part.
Re: Air Temp Sensor in Air Cleaner [Re: aar1] #1092713
10/11/11 03:11 PM
10/11/11 03:11 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
If you do a web search for Air Temperature Sensor 3514168 this is just a part of a list of 163 applications that comes up so I would think Rock Auto or NAPA has something:
MikeR
Compatibility Chart
Make Model Year Engine Notes
Chrysler All 1980 3.7L L6 Air Cleaner Temperature Sensor
Chrysler All 1971 5.9L V8 Air Cleaner Temperature Sensor
Chrysler All 1971-1972 5.9L V8 Air Cleaner Temperature Sensor
Chrysler All 1972 5.9L V8 Air Cleaner Temperature Sensor
NEWPORT, TOWN & COUNTRY
Chrysler All 1970-1971 6.3L V8 Air Cleaner Temperature Sensor
Chrysler All 1971 6.3L V8 Air Cleaner Temperature Sensor
w/2 BBL
Chrysler All 1972 6.6L V8 Air Cleaner Temperature Sensor
Chrysler All 1972-1973 6.6L V8 Air Cleaner Temperature Sensor
Chrysler All 1973-1974 6.6L V8 Air Cleaner Temperature Sensor
NEWPORT
Chrysler All 1974 6.6L V8 Air Cleaner Temperature Sensor
w/2 BBL
Chrysler All 1970-1971 7.2L V8 Air Cleaner Temperature Sensor
w/2 BBL
Chrysler Cordoba 1980 3.7L L6 Air Cleaner Temperature Sensor
Chrysler Cordoba 1980 5.2L V8 Air Cleaner Temperature Sensor
3514168~3514168
Chrysler Cordoba 1980 5.9L V8 Air Cleaner Temperature Sensor
Chrysler LeBaron 1980 3.7L L6 Air Cleaner Temperature Sensor
Chrysler LeBaron 1980 5.2L V8 Air Cleaner Temperature Sensor
3514168~3514168
Chrysler Newport 1980 3.7L L6 Air Cleaner Temperature Sensor
Chrysler Newport 1971 5.9L V8 Air Cleaner Temperature Sensor
Chrysler Newport 1972 5.9L V8 Air Cleaner Temperature Sensor
Chrysler Newport 1974 5.9L V8 Air Cleaner Temperature Sensor
NEWPORT
Chrysler Newport 1970, 1971 6.3L V8 Air Cleaner Temperature Sensor
Chrysler Newport 1972 6.6L V8 Air Cleaner Temperature Sensor
Chrysler Newport 1973, 1974 6.6L V8 Air Cleaner Temperature Sensor
NEWPORT
Chrysler Newport 1972 7.2L V8 Air Cleaner Temperature Sensor
3514168
Chrysler Newport 1973, 1974 7.2L V8 Air Cleaner Temperature Sensor
3514168
Re: Air Temp Sensor in Air Cleaner [Re: aar1] #1092714
10/11/11 03:14 PM
10/11/11 03:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Air Temp Sensor in Air Cleaner [Re: A12] #1092715
10/11/11 03:16 PM
10/11/11 03:16 PM
aar1 Offline OP
aar1  Offline OP
Mike,
I tried NAPA......... they have nothing. Rock Auto shows it on their website but I went to buy it and something comes up that says they don't have them and don't know if they ever will.
Anyway, I tried those two sources before posting the question here.
