70 B-Body P/S pressure hose part # HELP #1092682
10/11/11 01:55 PM
10/11/11 01:55 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Can someone help me out with the part number for the power steering pressure hose for a 70 RR with the Federal pump? I was checking for it in the FSM but never found it.
TIA!!!!
Re: 70 B-Body P/S pressure hose part # HELP [Re: LimeliteAero] #1092683
10/11/11 02:05 PM
10/11/11 02:05 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
TIA!!!!
what engine ?
Re: 70 B-Body P/S pressure hose part # HELP [Re: gtx6970] #1092684
10/11/11 03:43 PM
10/11/11 03:43 PM
SE Pa.
SE Pa.
I knew I would forget something!
440....
Re: 70 B-Body P/S pressure hose part # HELP [Re: LimeliteAero] #1092685
10/11/11 03:49 PM
10/11/11 03:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
You may have to go with a c-body or different year hose to get one that works/fits.
I believe the Federal pump was only used with the HEMI & 318 in a '70 b-body.
The HEMI also used a 90* fitting at the steering box end.
Re: 70 B-Body P/S pressure hose part # HELP [Re: 6bblgt] #1092686
10/11/11 04:08 PM
10/11/11 04:08 PM
SE Pa.
SE Pa.
I guess I should have asked this when I was more attentive.
I have the Saginaw pump with the oval reservoir.
sorry for the confusion and thanks for the patience.
Re: 70 B-Body P/S pressure hose part # HELP [Re: LimeliteAero] #1092687
10/11/11 04:23 PM
10/11/11 04:23 PM
It's a dry heat
It's a dry heat
2891078 is the only one listed for B engine B-body
