I have a 8 3/4 rearend out of a '67 B body that I have been planning to use in my 1968 Barracuda notchback (A-body)...
I measured it last night, and found that it was wider than I thought it should be. So, I compared it to the info in the Tech archives, and sure enough, it turns out that it IS NOT from a B-body, but is from a C-body. (I did not have the measurements with me when I bought it years ago, and just pulled it out of storage.)
I had planned on using a B-body 8 3/4 to widen the rear track a little (from stock A-body track), and to obtain better wheel fitment (through increased backspacing tolerences). I do not yet have wheels or tires picked out, so at least there isn't anything I have to try to work around (yet).
My plan for the car is to make an extremely aggressive, handling street car, with an occassional trip to a road race or autocross track. Because of my desire for the car to handle, I am trying to keep it balanced and as light as possible (especially the unsprung weight).
My question is, what do I do about the rearend now? Would I be money ahead to start over with another rearend? Or, are there effective ways to work with what I have got? I am open to input!
Here are the options I see, and potential 'cons' for each:
1. Scrap the C-body rear and get a B-body 8 3/4 like I had planned for. Which would be additional cost. (Is there even a market for C-body 8 3/4's beyond scrap?)
2. Have it cut down to a B-body width, and have the ends rewelded on. Again, additional costs, but would be less(?) than an entirely new rear. I haven't checked how much though. Plus, I worry about finding a shop that will do it right, know what I mean?
3. Ford 9"... I am not opposed to this on principal, or anything, I had just planned to keep it Mopar. Plus, I have NO idea what these are going for.
4. Dana... Again, not opposed to this either, but I only expect to put out maybe 500 hp max (hence the need for the car to be LIGHT), and this might be overkill. (Then again, if it is worth doing, it is worth over-doing!)
5. ?? Some other rear end?? Here is where my lack of knowledge really suffers. I recall people using other rears under A-body's, but can't recall any specifics now that I need them (of course)!
Please give me some advice and feedback.
ESPECIALLY if you have experience with some of these different types of rears, or have gone through something similar.
Thanks in advance!
