auto transmission cooler line brackets #1092536
10/11/11 07:47 AM
10/11/11 07:47 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
Do either of these repo cooler line brackets look like the original?
http://www.megapartsusa.com/proddetail.asp?prod=107%2DTLB162
or part # SR190 below....can't get it to go directly to product but it is the first on the list in my webpage
http://www.yearone.com/serverfiles/fbsho...p;SM=1&SC=1
Re: auto transmission cooler line brackets [Re: BTTG] #1092537
10/13/11 09:19 AM
10/13/11 09:19 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
Anybody?
Re: auto transmission cooler line brackets [Re: BTTG] #1092538
10/13/11 10:47 AM
10/13/11 10:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
EDIT ... Having second thoughts on this one ...
Re: auto transmission cooler line brackets [Re: BTTG] #1092539
10/13/11 04:26 PM
10/13/11 04:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There are at least a half-dozen different cooler line brackets, depends on the year/engine. If you're not concerned with originality just get one that works.
Re: auto transmission cooler line brackets [Re: John_Kunkel] #1092540
10/13/11 04:35 PM
10/13/11 04:35 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
69 B-body w/ 440????? If anyone knows.
As this is an item you only buy once, and pay way too much for it as a repop, might as well get as close to original as I can.
Re: auto transmission cooler line brackets [Re: BTTG] #1092541
10/13/11 05:09 PM
10/13/11 05:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The parts book doesn't show anything special for the 440 A-body, the most common bracket is pictured below...notice the bent up ears that grasp the starter flange to keep the bracket from rotating.
