Compression height vs stroke ?
#1091968
10/10/11 09:28 AM
10/10/11 09:28 AM
Posts: 976 ontario canada
mac56
ontario canada
I wondering if anyone can tell me if I could go to a 4.150 stroke with a 1.48 compression height piston on low deck or will the rod be too short? Thanks
Re: Compression height vs stroke ?
[Re: mac56]
#1091969
10/10/11 09:39 AM
10/10/11 09:39 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I wondering if anyone can tell me if I could go to a 4.150 stroke with a 4.80 compression height piston on low deck or will the rod be too short? Thanks
4.8 ? Centimeter ? Because if that's inches , the rod will be VERY short.
[Re: tubtar]
#1091970
10/10/11 09:49 AM
10/10/11 09:49 AM
mac56
ontario canada
Thanks for catching that. It has been corrected.
[Re: supercomp]
#1091972
10/10/11 12:31 PM
10/10/11 12:31 PM
mac56
ontario canada
With a chevy K1 6.405 long rod and 9.970 deck height the piston would be .010 down.
What I was concerned with would that bring the piston with that combination too far out the bottom of the bore?
[Re: mac56]
#1091974
10/10/11 11:05 PM
10/10/11 11:05 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Low deck height is 9.97 so take 9.97 subtract half the stroke so, 4.15 Divide by 2 is 2.075 subtract rod length of your choice subtract compression height this will tell you height from deck. ![](/ubbthreads/images/graemlins/wave.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 23T Hemmee]
#1091976
10/11/11 06:46 AM
10/11/11 06:46 AM
mac56
ontario canada
In a word, "No" unless your concern is piston/counterweight clearance. That would actually improve slightly with a 1.48 CH" as opposed to say a 1.32". Just curious, are you looking at my ad in Big Block parts. My pistons are 1.48's.....
No I wasn't I have a 3.915 stroke combo and was wondering if I could go 4.150 without buying pistons.
[Re: supercomp]
#1091978
10/11/11 11:15 AM
10/11/11 11:15 AM
mac56
ontario canada
With a 6.405 rod, a 4.150 crank and a 1.48 compression height piston, you will have .010 deck clearance with a 9.970 deck height. However the crank counterweights will have to be cut down to about 7.22 to have .075 clearance between crank counterweight and piston. That should work.
Thanks for the info Allen
