SB 4" strokers and timing ? #1091294
10/09/11 03:38 PM
10/09/11 03:38 PM
Guitar Jones Offline OP
So I have small chamber W5's, 53 cc's, a pretty tight quench at .031 and about 12.7 compression. I ran my old 360 at 34* and never screwed with it. I guess what I'm wondering is with the increased piston speed of the stroker I probably don't need as much advance. I had it set at 34 initially and I just knocked it back to 30 and it sounds better just running in the garage.
I know I need to experiment but I can't get out to the track now until November. I was going to go today but there is a storm system to the south of us that is just wreaking havoc on the weather. So what have you all found your car likes?
Re: SB 4" strokers and timing ? [Re: Guitar Jones] #1091295
10/09/11 03:41 PM
10/09/11 03:41 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
My old W5 engine only had a 3.800 stroke and liked 32*
Re: SB 4" strokers and timing ? [Re: SB412DUSTER] #1091296
10/09/11 04:16 PM
10/09/11 04:16 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
My 408 only liked 32 degrees. Any more and power would go down.
Re: SB 4" strokers and timing ? [Re: viperblue72] #1091297
10/09/11 04:25 PM
10/09/11 04:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine picked up going from 34* to 32*, it has .034" quench. In one of Ryan's posts a couple years ago he posted some dyno results on one of his engines. The engine had good quench and small chamber heads with dual quench pads. IIRC it made the most power at 28*.
Re: SB 4" strokers and timing ? [Re: justinp61] #1091298
10/09/11 04:28 PM
10/09/11 04:28 PM
That was my thinking too, These heads have double quench pads, I may knock it down to 26 to start with.
Re: SB 4" strokers and timing ? [Re: Guitar Jones] #1091299
10/09/11 04:52 PM
10/09/11 04:52 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
My 364 made most power at 39*. Same topend on my 4.125 stroke 436ci and dyno session it appeared the timing was at ~38* where it made most power but I don't think Ryan's light was working correctly so the distributor was just marked. Unfortunately I had to take the distributor out when putting the engine back in so the only thing I could do was line up the mark as close as possible and that's where it comes up around ~38.
I still have gremlins on this car and it still doesn't appear to have the power that it should have. I am hoping to get it to a chassis dyno soon so I can find out exactly where the timing should be. Will keep all informed. :-)
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: SB 4" strokers and timing ? [Re: W5Duster436] #1091300
10/09/11 05:03 PM
10/09/11 05:03 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
started out @ 32* went to 34* and it seemed to like it,,,that is where I am at today.
Re: SB 4" strokers and timing ? [Re: dartman366] #1091301
10/09/11 08:11 PM
10/09/11 08:11 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
mine liked 35 the best
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: SB 4" strokers and timing ? [Re: dusturbd340W5] #1091302
10/09/11 08:34 PM
10/09/11 08:34 PM
PA
moparacer Offline
moparacer  Offline
PA
Same here.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: SB 4" strokers and timing ? [Re: moparacer] #1091303
10/09/11 09:47 PM
10/09/11 09:47 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
W5s with 59cc chambers 12 to 1 , on race 110 34/36 on AV gas 100ll 32/34 on 3/4 AV to 1/4 shell 93 mix 30/32 this mix makes the most power so far but still foolin with it
Re: SB 4" strokers and timing ? [Re: emarine01] #1091304
10/11/11 12:44 AM
10/11/11 12:44 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
My 10.6-1, 439" with small chamber W5's was at it's best @ 32*, anything more and it lost significant power according to Ryan J.
Re: SB 4" strokers and timing ? [Re: 72demon416] #1091305
10/12/11 04:05 PM
10/12/11 04:05 PM
dogdays Offline
dogdays  Offline
It's 100% the combustion chamber and doesn't matter what shortblock is under it. (Of course, the top of the piston is the bottom of the combustion chamber.) The better the chamber the shorter ignition lead required for max power.
R.
Re: SB 4" strokers and timing ? [Re: dogdays] #1091306
10/12/11 05:29 PM
10/12/11 05:29 PM
R.
Hmm, I have a 20cc dish piston including the .350 deep valve reliefs so it's not a lot of dish.
Thanks for the answers, I guess I'm in the ballpark at 30 and I'll work from there.
Re: SB 4" strokers and timing ? [Re: Guitar Jones] #1091307
10/12/11 05:48 PM
10/12/11 05:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
I would think that you would be better off with a
bit more timing... my W-9 likes 34* and most of my
W heads like right at 34* or a touch more... I'm talking
W-2, W-5, or W-9... I'm gonna have to test with my
W-5s on my 416 and pump gas to see what it likes...
I set it up for 34* to start with
Re: SB 4" strokers and timing ? [Re: dogdays] #1091308
10/12/11 10:46 PM
10/12/11 10:46 PM
Az
Crizila Offline
Crizila  Offline
Az
R.
Fastest 300
Re: SB 4" strokers and timing ? [Re: Guitar Jones] #1091309
10/13/11 02:31 PM
10/13/11 02:31 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
i had w5's on a 416 shortblock about 11.5 compression with a 260/266 flat tappet that through trial and error found it was fastest with 40 degrees of timing...turn it back and the car fell off,..was a tenth slower with 34/36 degrees in it on back to back laps.
fast forward, same heads on a new 13.3 roller 422 shortblock, car ran best at 32 degrees, i could put 28 in it and that killed a tenth....so, it depends...
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
