Why is my odometer not accurate?
#1091061
10/09/11 12:25 AM
10/09/11 12:25 AM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
My 67 Coronet street car - - the speedometer is pretty much dead on, but the odometer is approximately 19% off (tacks on more miles than actual)? What causes this?
Re: Why is my odometer not accurate?
[Re: markz528]
#1091062
10/09/11 06:12 AM
10/09/11 06:12 AM
Posts: 4,740 Florida
BDW
My guess is the magnetic pick-up / bushings needs rebuilt. I think the miles are a result of the cable directly turning a set of gears.
But the speedo needle actually moves by a closely toleranced magnetic assembly.
Does the needle jump around? Mine eventually broken and had to get the bushings repaired.
*** OOPS, re-read and I got it backwards, I guess for some reason the gear portion of yours needs attention.
[Re: markz528]
#1091063
10/09/11 07:42 AM
10/09/11 07:42 AM
RapidRobert
I'd get the right speedo pinion into the trans (more teeth) to get the odo spot on (check on interstate mile marker signs which are pretty accurate) then at that point if the speedo is inaccurate (checked at a roadside digital MPH sign) then the speedo head needs to come out & delivered to a speedo specialty shop & they'll most likely want to know the percentage of error (& which way). Put a piece of flat stock on top of a rear tire and measure the actual dia to ground then with your rear gear ratio # go to the archives chart & find the tooth count you need & get one & install it & go from there. #1 need the right pinion to mechanically make the odo correct then see if that makes the magnetic gismo in the speedo correct also
[Re: John_Kunkel]
#1091065
10/09/11 04:13 PM
10/09/11 04:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Doesn't the "flat spot" on the bottom of the tire affect that method?
It sure do. Would be better off to measure across than up and down unless tire is off the ground. But what do we know John????
[Re: BDW]
#1091067
10/09/11 11:01 PM
10/09/11 11:01 PM
RapidRobert
Yes measuring rollout with a tape measure would be dead on and you're only talking 7-8 feet but I did mine top to bottom and with the gear ratio in hand picked the right one from the chart & it made my odo and the speedo correct but I'm gonna listen to what Kunkel has been telling me for years and next time measure rollout. EDIT and John you just divide Pi into the rollout for the dia right?
[Re: RapidRobert]
#1091068
10/10/11 05:56 PM
10/10/11 05:56 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just divide the rollout in inches by 12 to get feet and divide that into 5280 to get the number of wheel turns in one mile.
[Re: John_Kunkel]
#1091069
10/10/11 06:06 PM
10/10/11 06:06 PM
RapidRobert
but I'm going to want diameter (along with gear ratio) to use the pinion chart. How is figuring tire revolutions per mile going to help with that?
