Re: There`s got to be a better way.......................
[Re: Thumperdart]
#1090463
10/08/11 11:20 PM
10/08/11 11:20 PM
dartman366
Mt. Vernon, Ohio
dom, if the intake is leaking, the paper should be saturated on the bottom side. look at the int.valve stems to see if oil is seeping past the seals. with all those yrs of street driving and that roller cam the guides might be worn.
But then why aren`t the ex. valves oiled? The guides check out ok when George checked em.......
because the exhaust side pushes and the intake suck's,,,,,literally,intake will pull oil from any place it will seep,, exhaust wil burn it in the port if the guides let a little oil past the valve stems.
[Re: dartman366]
#1090464
10/08/11 11:39 PM
10/08/11 11:39 PM
Posts: 2,119 sc
tjmarcus1
sc
exactly!!!!!
[Re: Thumperdart]
#1090467
10/09/11 11:57 AM
10/09/11 11:57 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
if the intake is the problem, Ultra Grey silicones work best but alot of valves look this way comming off stock engines, i would check the guide clearances and put new seals on the heads
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Thumperdart]
#1090469
10/09/11 07:19 PM
10/09/11 07:19 PM
sixpackgut
Charleston
Again, the guides checked out fine and we put the new blue bad ass seals on when we did the heads 8 months ago.
i must have missed that. ultra grey is your friend then
