1971 Dodge Truck, Power Steering Conversion?
#1088768
10/05/11 12:09 PM
10/05/11 12:09 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Has anyone converted a older Dodge truck from manual to power steering? Are there any kits available? I've found a 71 short bed sweptline, 318, auto, no power anything. In my older years I like power steering, brakes and air conditioning .
Re: 1971 Dodge Truck, Power Steering Conversion?
[Re: Magnumguy]
#1088772
10/05/11 04:52 PM
10/05/11 04:52 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
There are no aftermarket kits available for these trucks. The original unit is a power assist and it can be hard to find parts to rebuild it.
If you haven't visited Sweptline.org, there are several options covered for converting to integral power steering.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Soopernaut]
#1088773
10/05/11 05:35 PM
10/05/11 05:35 PM
justinp61
W. Kentucky
Thanks guys . Bigdad......What did you put under the front of yours? Photos?
[Re: bigdad]
#1088775
10/05/11 07:55 PM
10/05/11 07:55 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Mine drives great without P/steering !
because I took that straight axle off
That truck is beautiful!!!! great job!
[Re: justinp61]
#1088780
10/05/11 09:54 PM
10/05/11 09:54 PM
Posts: 34,884 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
No sir, don't ..
You can pickup almost any street rod magazine and they install a kit in something every month
It is not terribly hard if you have a well equiped shop, welder, sawsall,etc
Or, contact a local hot rod shop they can help you do it
everyting on my is custom for mine, measurements etc vary from installation to install
I built new crossmembers, fuel tank, you name it
Its pretty trick
[Re: bigdad]
#1088781
10/05/11 10:06 PM
10/05/11 10:06 PM
POS Dakota
detroit, mi
I put independent front susp from www.fatmanfab.com the rear is a fatbar sstem from www.nolimit.net
Thanks, it rides,drives and stops with disc brakes great now !
Yep, they make really nice setups. Even a really affordable entry level kit. All of which make setting up steering so much easier and cleaner.
[Re: RUNCHARGER]
#1088783
10/06/11 03:06 AM
10/06/11 03:06 AM
Posts: 233 vashon island washington
hunterstroble
The factory p/s set up is a joke, leaks lots of turns lock to lock. As stated above sweptline.org is an oasis of information.
1969 Dodge dart 500 stroker
1973 Dodge Challenger 440
