What cam is this?
#1088619
10/05/11 01:03 AM
10/05/11 01:03 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I finally got the cam out of the engine I bought. The engine is a rebuilt 1974 440 with steel crank. One cylinder had water in it but it looks to be a low mileage rebuild, albeit it came out of a mud bog truck that broke and rolled. The end of the cam has alphabet soup stamped into it. No brand names. 272 P 64-1 1424 8A5H I googled the crap out of it. The only cam I could find was a CamCraft.com. You can see the specs on the cam under letter "C". It's labelled 21-1424 I plan to put a call in to them unless one of you motorheads can ID this baby. So if these are the true numbers, how aggressive is this cam? Is it like the old 282 MP purple Hyd cam? Lift, duration, lobe separation, it's stuff I have heard for years but it's still greek to me. Lindy
I’m listening.
Re: What cam is this?
[Re: emarine01]
#1088621
10/05/11 01:26 PM
10/05/11 01:26 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Looks like stock cam markings to me, or maybe a MP grind also. They really dont have any kind of ID with numbers... They have stamps and marks, but I havent ever figured out what they mean. Take some calipers and measure lobe lift... Pretty simple, and you will get a idea of what it is.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: RemCharger]
#1088623
10/05/11 01:44 PM
10/05/11 01:44 PM
Big Bad Bee
Spokane Valley, WA
Called CamCraft. Nope. They don't claim it. They usually don't mark their cams. The owner said that it's likely a custom grind/regrind and said that I need to look at the casting for marks but even that won't likely tell the story. Might be an older Crane Cam number set, referring to the 1424. Suggested I go to someone with a "Cam Doctor" to have it measured. I'm going to call my engine guy and see what he's got. Maybe do the calipers and dial indicator for fun. Thanks for the suggestions, guys. Lindy
I’m listening.
[Re: Big Bad Bee]
#1088624
10/05/11 02:02 PM
10/05/11 02:02 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Lindy
In all honesty though do you really plan on re using it? If its a solid flat tappet, or hydraulic cam is it worth saving especially if you dont know what specs is ground on. I guess for what Comp will sell you a nice cam and lifter set for I would just buy a new one, but if your on a tight budget I understand that also.
kasey
[Re: Big Bad Bee]
#1088625
10/05/11 02:19 PM
10/05/11 02:19 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Lindy
Its odd they don't claim that cam, The 272 is the Adv. Dur., The 1424 is the core #, Its ironic that on there cam chart it shows the 1424 as a .272, i'd measure the lobes.
[Re: joedust451]
#1088626
10/05/11 03:53 PM
10/05/11 03:53 PM
Posts: 137 Daytona Beach, FL
cknight
Daytona Beach, FL
If it's a single bolt camshaft, it could be one of the old Crane private label hydraulic lifter grinds. Duration at .050" would be 214 intake, 224 exhaust. Timing at .050" is: Intake opens 0 BTDC, intake closes 34 ABDC, exhaust opens 49 BBDC, exhaust closes 5 BTDC. Advertised duration is 272 intake, 282 exhaust, at .004" lobe lift. Lobe separation is 112 degrees. Lobe lift is .2947" intake, .310" exhaust, providing a gross valve lift with 1.5:1 rockers of .442" intake, and .465" exhaust. Regards, Chase
[Re: 6PACMAC]
#1088632
10/11/11 01:55 AM
10/11/11 01:55 AM
Big Bad Bee
Spokane Valley, WA
Thanks! I hadn't checked back to this post for a couple days. I am always astounded by the wealth of knowledge here. I am ditching the cam for something more aggressive. The block goes to the engine builder this week to see if the bore can be fixed. With me luck.
Lindy
I’m listening.
