Re: 1966-67 B-Body Hood Springs
[Re: 66Plymouth440Six]
#1088572
10/07/11 12:51 AM
10/07/11 12:51 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
You're goiing about it a little backwards, but we can still fix it...
You need a piece of 1/2" square tubing with some small v-notches ground into the ends. The goal is to get the tube to be inside the spring and holding it in a partially extended configuration. Measure the distance between the hooks when the hood is open, and add about 3/4". That will be the length of the tube. Find 2 rigid points about 3 feet or so apart, anchor the spring to one and a good rathcet strap the the other. hook the other end of the ratchet strap to the spring and start ratcheting until you stretch the spring enough to get the tube inside the spring and inline with the hooks so as you slowly unratchet (do not just release it!) it will come to rest on the notches in the tube in a partially extended position. Take that assembly and install it on the hinge and then "close" the hinge (easiest if it is installed on the car hood and all) and the spreading action of the hinge's spring mounts should take the spring and stretch it out, releasing the tube.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: RestoRick]
#1088574
10/07/11 01:25 PM
10/07/11 01:25 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
I've always used an old fan belt. Hook the rear of the spring on the hinge and loop the belt on the front hook. While someone is holding the hood up, pull the belt and ease it in place.
Justin "CornDog"
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
[Re: CornDogsCharger]
#1088575
10/07/11 10:52 PM
10/07/11 10:52 PM
Posts: 1,090 Saskatchewan, Canada
barracudabob
Put the end of the spring in a vise, and flex the spring slightly sideways.. This will create a gap between the winds of the spring. Jam washers in the spaces. Now flex the spring the other direction, and fill the gaps in the other side of the spring with more washers. You'll have to do as many of the winds as you can, but it will get long enough to reach. When you get it on, start closing the hood, the spring will expand, and the washers will start to fall out.
