Re: damaged cyl. wall
[Re: 65rbdodge]
#1087607
10/03/11 03:03 PM
10/03/11 03:03 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Look for another block
[Re: Cab_Burge]
#1087614
10/03/11 03:35 PM
10/03/11 03:35 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
How about sleeving the bad cylinder along with the new piston? I would
Your suggestion and mine both go beyond this being a BUDGET build.
I think he got enough votes to do what he wants to do which is just slap it together, that one cylinder will be done on power due to compression loss .
[Re: dOOc]
#1087615
10/03/11 03:39 PM
10/03/11 03:39 PM
Challenger 1
Cincinnati, Ohio
I would FIND anutter block ... BTW ...what did you have to pay for it from a JY ?
I told you Doc how hard those motorhome 360s work, those valves get hot and fail over time. Been there.
[Re: gtx6970]
#1087617
10/03/11 03:54 PM
10/03/11 03:54 PM
JohnRR
U.S.S.A.
sleeving it now would be cheaper than time and materials to pull it back apart later
my
At 85 bucks it would be cheaper to get another engine. I've been around this site long enough to read people ...
[Re: 65rbdodge]
#1087620
10/03/11 04:32 PM
10/03/11 04:32 PM
JohnRR
U.S.S.A.
i got it from a upullit about 3 years ago so it was sold as is. was in a 74 motorhome with a casting date of 6/30/73
That should be the thickwall block , slap it together and run , you probably won't notice it as mentioned.
[Re: Challenger 1]
#1087622
10/03/11 05:33 PM
10/03/11 05:33 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
Any MH motor can be worked big-time. AND the A engine was not built as well to handle those rigors like the 413 was. Valves failing ? ... it is mostly due to the seats burning up, the valve sinks into the head and then the keepers fall out ...
[Re: POS Dakota]
#1087624
10/03/11 06:18 PM
10/03/11 06:18 PM
dOOc
Florida STAYcation
Just use a can of engine restore. It works. I saw it on TV.
ORE ...JB Weld ...
