Difference in coolant passages #1085383
09/29/11 09:33 PM
09/29/11 09:33 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hello! Probably a dumb question, but...Why do some big blocks have coolant passages that are "O" shaped and some that look like a sideways "8". I'm talking where the head gasket seals. Laying the head gasket on the block, looks like the "O" style has almost no flow opening. I have 2 blocks side-by-side and just noticed this. Which is better? Or am I overthinking this lol! Thanks, Jeff
Re: Difference in coolant passages [Re: 1969RR] #1085384
09/29/11 10:20 PM
09/29/11 10:20 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
The "oval 8" holes are for better cooling.Here's link to info about big blocks:
440 block info
Re: Difference in coolant passages [Re: 1969RR] #1085385
09/29/11 10:26 PM
09/29/11 10:26 PM
I would highly suggest drilling a 1/2" additional cooling hole between cyls 3/5 and 4/6 on the outer (outside) edge between the 2 head bolt holes to form a triangle. Punch do not drill a hole in the gasket and drill a matching 1/2" hole in the head(s). This a very hot area (between 2 ex valves) & needs the help. I would also drill the existing outer holes to at least 3/8" and add some at the end of each bank. No downsides to this & just need spacial awareness for how much surface area is available to you to work with EDIT and how close you are to the edges/cyls (drill a small hole 1st & look inside)
Re: Difference in coolant passages [Re: RapidRobert] #1085386
09/30/11 03:49 PM
09/30/11 03:49 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hi Guy's! Didn't get a chance to thank ya both yesterday. So, Thank you! Still find it odd that the head gasket has such a small "slit" in that area for the water to flow through. If the block passage is that big, how come the gasket is so small?? Take care! Jeff
Re: Difference in coolant passages [Re: 1969RR] #1085387
09/30/11 04:26 PM
09/30/11 04:26 PM
yes open them up either with a gasket punch set (HF has em for less than $10) or exacto knife/razor blade just dont drill em or it'll grab the gasket & shred it
