Page 5 of 5 1 2 3 4 5
Re: Turbocharging for economy [Re: feets] #1085128
10/11/11 03:31 PM
10/11/11 03:31 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Now you guys went and made him angry.
Re: Turbocharging for economy [Re: TRENDZ] #1085129
10/11/11 03:56 PM
10/11/11 03:56 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
OK?
Now what?
OK, if we're gong to play THAT game:
Cause and effect....
I put a turbo on my truck.
I didn't change the programming in the PCM for a turbo, so when I'm not in boost it doesn't know it has a turbo on it.
I get better fuel mileage now.
That's cause and effect.
Yeah, I already told you guys WHY, but apparently it was supposed to COST me fuel mileage and it didn't. I don't believe the efficiency changed one single bit when I'm not in boost.
Re: Turbocharging for economy [Re: feets] #1085130
10/11/11 04:35 PM
10/11/11 04:35 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I'm out of this one.
Maybe your blood pressure will go down some then! Geez, it's just a web board with a question...
Re: Turbocharging for economy [Re: Duner] #1085131
10/11/11 05:03 PM
10/11/11 05:03 PM
IL
furious70 Offline
furious70  Offline
IL
OK?
Now what?
you already said it was cuz you started [Edited by Moparts - Family Friendly Site - Keep it clean] footing the truck vs how you drove it b4. That's a different argument that states changing your driving characteristics can actually effect mpg. Anyone going to argue that one and say that there's less pumping losses at WOT so you should get better mpg by hammering on it?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Turbocharging for economy [Re: furious70] #1085132
10/11/11 06:07 PM
10/11/11 06:07 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I don't think it hurt the mileage by putting a turbo in the exhaust path - especially compared to the restrictive stock setup vs the turbo and big exhaust. That's all I am really trying to get across. Then again, I'm not driving an antique with a carbentator either.
Re: Turbocharging for economy [Re: Duner] #1085133
10/11/11 09:40 PM
10/11/11 09:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think the main thing is A. He WILL NOT improve mpg w/ a turbo but B. he WILL improve his HP and torque.
Re: Turbocharging for economy [Re: Mr.Yuck] #1085134
10/17/11 12:51 PM
10/17/11 12:51 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I guess the First law of thermodynmics does not apply to turbos. I always thought heat/energy sent out the exhaust was wasted and deducted from the total efficency of the engine. I also thought using that wasted exhaust heat and energy to spin a turbo was beneficial to improving cylinder filling. I also thought it if it took x amount of gallons of fuel to move a car y amount of miles and z amount of heat went out the exhaust, by lowering z I could go Y+ miles or use x less gallons.
Guess I was wrong.
http://en.wikipedia.org/wiki/First_law_of_thermodynamics
Re: Turbocharging for economy [Re: jcc] #1085135
10/17/11 04:09 PM
10/17/11 04:09 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
Guess I was wrong.
That's not necessarily wrong, but, again, fails to account for the fact that while traveling at low-load highway speeds, a turbocharged IC gas engine is still making vacuum and not seeing any boost or associated benefits. So, the heat passing through the turbo and out the exhaust is still "wasted".
Pretty sure that was covered on the first page though.
Re: Turbocharging for economy [Re: EV2DEMON] #1085136
10/17/11 05:22 PM
10/17/11 05:22 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I figure at this point people are just trolling since there is three pages of information on the subject that pretty much covers it.
Re: Turbocharging for economy [Re: EV2DEMON] #1085137
10/17/11 07:50 PM
10/17/11 07:50 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
And is that because the turbo is oversized for power instead of economy by choice?
I'll reread the first page.
Re: Turbocharging for economy [Re: jcc] #1085138
10/18/11 12:15 AM
10/18/11 12:15 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
No, It's because if it was making boost it would be accellerating. If it's not making boost it's a parasitic loss. IF YOU ADD MORE AIR YOU NEED MORE FUEL.
Re: Turbocharging for economy [Re: EV2DEMON] #1085139
10/18/11 11:20 AM
10/18/11 11:20 AM
IL
furious70 Offline
furious70  Offline
IL
Guess I was wrong.
This point would apply more to an industrial or constant load application where you are always making boost.
70 Sport Fury
68 Charger
69 Coronet
72 RR
