Can i just paint a white line........ #1084829
09/29/11 12:34 AM
09/29/11 12:34 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
on my ATI balancer and read it with the timing light?The mark on the balancer r so hard to read if so is there a certain type of paint i should use..............Thax.
Re: Can i just paint a white line........ [Re: racerx] #1084830
09/29/11 12:46 AM
09/29/11 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats all I do... I use a paint pen(white) and mark
where you want the timing to be... in my case I marked
34*... plus I mark the 0 on the pointer, that way I
just line up the lines
Re: Can i just paint a white line........ [Re: racerx] #1084831
09/29/11 02:27 AM
09/29/11 02:27 AM
White out(correcting fluid) works real well, put it in the mark and wipe the rest off Clean the dampener real well of course before using it, laquer thinner removes the excess real well also
Re: Can i just paint a white line........ [Re: Cab_Burge] #1084832
09/29/11 06:02 AM
09/29/11 06:02 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax. fellas head out to my local Walgreen's and pickup some whiteout.
