Re: copper like shavings in the oil...?
[Re: 72swinger360]
#108429
08/21/08 02:28 PM
08/21/08 02:28 PM
RapidRobert
I hate to be the bearer of bad news. BEARINGS.
[Re: 6T6Cuda]
#108434
08/21/08 03:20 PM
08/21/08 03:20 PM
Posts: 182 Idaho
72swinger360
Idaho
The oil pressure was great. up around 60psi. I had a problem with the previous cam. It scrached a few of the bearing, plus one wasn't perfectly lined up. So I went ahead and had all new one installed. I have a hard time thinking thats whats causing it. I sure hope it's simplier than that. I'm tired of the car beeing on jackstands 95% of it's life! I'll Check it out tho. Thanks Jake
[Re: 72swinger360]
#108443
08/21/08 10:31 PM
08/21/08 10:31 PM
RapidRobert
You might peruse this site & checkout Sanborns oiling mods. he's a circle burner & is at the top of his game in regards to high rpm SB oiling mods. go to www.moparchat.com then scroll down to & click on circle track chat & Sanborns oil mods will be in a sticky at the top. It will take a long time to get through it all because there is alot of material to cover but it is EXCELLENT. & alot of it can be applied to big blocks as well.
[Re: 72swinger360]
#108444
08/22/08 09:20 AM
08/22/08 09:20 AM
Posts: 2,874 Upstate, NY
sixpack4spd
Upstate, NY
The motor hit pretty high up on the tack. I couldn't tell you exactly how many rmps it saw, but the motor started knocking right after that.
That info would have made it a LOT easier to diagnose your problem.
