Re: Ladder bars for 62-65 B bodies
[Re: sjs64polara]
#1084089
09/28/11 01:09 AM
09/28/11 01:09 AM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A lot of improvement over leafs or caltracs would mean those two types of set ups were not very optimized if the car is slower than about 11.00, and caltracs should be good at better ETs than that. But I definitely recommend going to ladderbars over either. They will work well for you down into the eights. They are the lightest of the three I believe. Also very easy to adjust. I run ladder bars and at 8.90s can run several passes in a row with 60 fts all within .005.
[Re: gregsdart]
#1084091
09/28/11 10:34 AM
09/28/11 10:34 AM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
Couple of facts about the current car from this past year. 3670 lbs 46.5% rear weight. (no weight in trunk) Caltracs running .05 gap. Rancho shocks work best at 3-5. Have to hit the tire HARD Front end travel is 5.5 inches and it’s very loose. 30x9 Hoosier DO5 slick on an 8” rim. Have 1/4-3/8 clearance each side before rubbing. Tire psi works best at 12.5 no tubes. 505 cubes, 640 roller .272 @ .050 with Rick Allison cross ram Low gear set with 4.10 gears. On a new good tire it 60 foots 1.44 /1.47 – that goes away after about 35 runs Car runs 10.5’s Work all season on wheel spin and the RacePak still shows an excessive amount.
[Re: sjs64polara]
#1084095
09/30/11 09:38 AM
09/30/11 09:38 AM
Posts: 1,401 Wi.
old_racer
Wi.
[Re: sjs64polara]
#1084096
09/30/11 09:43 AM
09/30/11 09:43 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Ok, let me ask this. Anyone running M/T 31 x 10.5 W with a 10 or 12 inch wheel just with mini tubs? Did you have to cut the outside wheel tub (closest to quarter panel skin)?
Yes I run a 63 with the 31x10.5W and a mini tub. On mine I have a 5.5 bs rim and use spacers and the inside tire rubs. I will change to a 4.5bs rim and they will fit inside and out with no issues using a 10" rim.
Russ
[Re: sjs64polara]
#1084098
10/27/11 12:05 PM
10/27/11 12:05 PM
Posts: 1,377 Ohio
Todd
Ohio
I'm running 6" Bilsteins with 32" ladder bars and leaf springs. The shocks can be converted over to coil overs if I ever decide to get rid of the leafs. Its been mini tubbed and has 31x13 tires on a 12" rim. The car weighs 3300 with me and 1600 lbs on the rear.
[Re: CRT]
#1084100
10/27/11 02:46 PM
10/27/11 02:46 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
I can't argue with the results you guys get with ladder bars but to me, and this is only my opinion, if you are going to go through the work and expense of putting in ladder bars why not just four link it? It's only a few hundred dollars more and you have an infinitely adjustable suspension. I mulled this over for many months, talked to a few chassis builders, and most of them said the CalTracs would be preffered just because of the adjustability. I put CalTracs on my Duster only because it's an original 340 4 speed car with rare and few options so I didn't want to cut it up. So when I decided to get serious I built a 4 link car out of a mundane run of the mill 318 car I got out of a junk yard. Again just my ![](/ubbthreads/images/graemlins/Twocents.gif) YMMV. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: sjs64polara]
#1084101
10/27/11 05:57 PM
10/27/11 05:57 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Using the Wallace calculator,,,for your car,,running 10.50's,,it predicts a 60' of 1.44-45 ( seems close to what you posted )
http://www.wallaceracing.com/calc60ft.php
The calculator is pretty spot on for my car ,,,and ET.
I run Caltrac's ,,, and keep chipping away at my ET with weight loss, shocks, convertor adjustment, carb squirters, timing, tire pressure, etc,,,and have been able to get from a 10.26 down to a 10.04,,,and the 60' improves as my ET improves,,,1.43-44,,,down to a 1.39-1.41 (451, solid cam, Edelbrock RPM heads, dominator, 456 Dana, 31 x 10.5 tire/tubes, caltracs, ranchos, etc)
good luck with the car,,,ps,,,GREAT pic in the original post,,,wheels up,,,
![](/ubbthreads/images/graemlins/thumbs.gif)
Doug
[Re: Guitar Jones]
#1084103
10/27/11 09:40 PM
10/27/11 09:40 PM
sjs64polara
Wisconsin
Again just my YMMV.
I couldn't keep the back seat with a 4 link. I still love driving my kids around on street cruzes. Wife said do what you want as long as we can still go for ice cream on nice summer nights with the family. LONG STORY.
[Re: 69CHARGERMD]
#1084104
10/27/11 10:16 PM
10/27/11 10:16 PM
sjs64polara
Wisconsin
Doug
I agree about the Wallace calculator , should be close. I put a RacePak in the car mid year and the G forces and drive shaft speed show a considerable amount of wheel spin on my 9inch Hoosiers. Been trying to reduce the vertical lines for months…….. The 60s only last 30-35 passes then drop to high 40s to low 50s. I think those Hoosiers are taking a beaten with my weight etc….
I’m planning on mini tubing it anyway this winter and the ladders wouldn’t be all that much more work. I have a very good friend that is a chassis builder and my brother also has built his fair share.
Thanks for all your input on the HHR fan and water pump, works great!
thanks to all for the input
[Re: sjs64polara]
#1084105
10/27/11 10:28 PM
10/27/11 10:28 PM
69CHARGERMD
KENTUCKY
Spencer, I am not too familiar with the RacePak,,but might do some research on it,,,do you find it helpful for dialing in the car,,,and diagnosing some issues ? Might pm you sometime and ask some questions on it if you dont mind. Which system do you use ??? I dont know anyone locally that uses it,,,but am always looking for stuff to get my car working better... Glad the fan and pump worked out.... Doug ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 69CHARGERMD]
#1084106
10/27/11 11:29 PM
10/27/11 11:29 PM
sjs64polara
Wisconsin
Doug
Its GREAT. I use the RacePak Sportsman data acquisition system. Yellow Bullet forum has some really good info and help with the RacePak stuff. No more guessing on what the car or I am doing. I’ve learned a lot from it. It really helps me understand changes and their effects. Some of the best $ I’ve ever spent on the car. PM me if you want to discuss more
thought it was just us Wisconsin guys ![](/ubbthreads/images/graemlins/grin.gif)
[Re: sjs64polara]
#1084107
10/28/11 12:50 AM
10/28/11 12:50 AM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
We run 32" ladder bars and Strange shocks untubbed with 12" wheels and 10.5x29.5 slicks We have been 1.2800 in the 60' and average 1.29-1.33. You must also get the front end setup correctly to get the best performance. poppaj
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
