Cuda door latches, I have a problem #1083583
09/27/11 09:53 AM
09/27/11 09:53 AM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
Ok, car is a 1970 Cuda.
Problem is I close the doors, and lock the doors with the key, BUT I just pull up on the handle and it opens like it was never locked??????????????????????
what gives, they supposedly worked just fine before, All i did was replate them
Re: Cuda door latches, I have a problem [Re: gtx6970] #1083584
09/27/11 10:51 AM
09/27/11 10:51 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Possible the key cylinder linkage rod/arm is installed incorrectly?, or drivers lock cylinder in passenger, passenger in drivers?
Re: Cuda door latches, I have a problem [Re: DAYCLONA] #1083585
09/27/11 12:48 PM
09/27/11 12:48 PM
It's a dry heat
It's a dry heat
Thanks Mike,
I figured it out this morning, all it was the exterior linkage adjustment was out ever so slightly and wasn't moving the lockout arm enough.
re-adjusted both sides , now they work
On to the next problem
