Re: OK 3th try with the E-85
[Re: VernMotor]
#1082195
09/25/11 04:22 PM
09/25/11 04:22 PM
Guitar Jones
So is there a problem you are trying to fix?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: emarine01]
#1082202
09/25/11 05:50 PM
09/25/11 05:50 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Whats the largest cfm/jet combo you tried on gas?
I have had my 850 Q/F up to 78-86.. It runs run fine there but it is way to moody to the air change.Around here you may see 1800 da to 4500 da in a days time. Not good to keep up with bracket racing. and they tell me my Q/F= quick fuel carb flow 930 cfm
[Re: sshemi]
#1082203
09/25/11 05:51 PM
09/25/11 05:51 PM
VernMotor
Mt.Vernon ,Ohio
my guess is that fuel starts to come through the boosters at 1300 rpms thats why the mix screws do VERY little change.
Really not a prblem but if its a street car it can be difficult to get the mix perfect throuout the circuits.
No street car and it seems to idle fine..Might be one of them things I am looking at to fix and it's not really broke LOL
[Re: emarine01]
#1082205
09/25/11 06:01 PM
09/25/11 06:01 PM
VernMotor
Mt.Vernon ,Ohio
Ok... I thought you had a longer stroke engine.... It all makes sense now
stock stroke..I am gald it makes sense to you ! Now expain it to me LOL
[Re: VernMotor]
#1082206
09/25/11 06:08 PM
09/25/11 06:08 PM
Guitar Jones
IFR .042
Jones just wonder if I should be albe to ajust the Idle mixer screws at 1200 rpms ? I thought I should ? and if the jetting and air bleeds was close ?
The throttle plate is open to far so it's past the idle circuit. Are there any holes in the throttle plates? If not try opening the secondary plates and closing the primary some. If that doesn't work you may need to drill holes in the primary plates or if it has holes they may need to be larger. This is so you can get the air flow needed but still keep the plates closed enough to use the idle circuit.
[Re: Guitar Jones]
#1082207
09/25/11 06:18 PM
09/25/11 06:18 PM
VernMotor
Mt.Vernon ,Ohio
IFR .042
This what I thought. But I am not not a great carb guy so I thought maybe I needed to change the IAB or something like that. drilling the holes is a old school trick I have done to older carbs that did't not have adjustable air bleeds.
[Re: VernMotor]
#1082208
09/25/11 07:00 PM
09/25/11 07:00 PM
Guitar Jones
IFR .042
You can make the circuit richer or leaner with the bleed but if the throttle is open past the transfer slots it won't make a difference.
[Re: 11secondC]
#1082210
09/25/11 08:32 PM
09/25/11 08:32 PM
VernMotor
Mt.Vernon ,Ohio
This is how my 850 is setup...
86/95 4.5" PV - 50cc pumps, Brown Cam's and 54 squirters.
.026" HSB .043" IFR .081" PVCR .067" LSB
Definitely lockout your distributor aswell...
wow you are really dumping the fuel with the pump/squirters. makes me fell better about bumping that all up. carb cam with orange cams and 37 squirters. Car would not leave the line went to pink cams and 42 squirters that help. So I got 45 in there now..I might need to go more !
[Re: VernMotor]
#1082211
09/25/11 09:35 PM
09/25/11 09:35 PM
Posts: 16,925 NC
440Jim
NC
has IAB .067 and HSB .028. So does this sounds close ??
Yes, that sounds close. But every combo can be slightly different.
The metering blocks and boosters will effect the main jets and air bleeds needed. Smaller on both air bleeds might help. From what I have seen, richer WOT might be worth trying, those 84/94 jets are not big for E85.
[Re: ajcasini]
#1082214
09/25/11 10:27 PM
09/25/11 10:27 PM
VernMotor
Mt.Vernon ,Ohio
Well I will run it Fri night with the set up in it and see where we get. and I will report back LOL Have not run it yet AJ now I got everything fix.
[Re: VernMotor]
#1082216
09/26/11 08:36 PM
09/26/11 08:36 PM
Posts: 16,925 NC
440Jim
NC
[Re: VernMotor]
#1082220
09/28/11 04:51 PM
09/28/11 04:51 PM
Posts: 2,128 sweden
sshemi
sweden
dont listen to what jets someone elses different carb has. If it runs good leave it. If you start to change air bleeds you will offset the whole fuel curve.
[Re: sshemi]
#1082221
09/28/11 10:06 PM
09/28/11 10:06 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
i have been running E85 now for three years now with no problems. i have a 3 circuit 1050 set up with the qwk fuel kit. i have went to 99 MJ and bumped up the timing 2 deg over my starting point in 2009. others i have converted also run with no problems. at MMW i ran a best of 9.89 with the trottle loose to run the 10.0 and john cope (CRT) ran a best of 9.94 and jerry hayes (MOPARPITTBULL) ran solid 9.80's with a smaller carb to slow it to the 10.0s. E85 ROCKS.....
WAXER
[Re: VernMotor]
#1082224
09/29/11 09:32 PM
09/29/11 09:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok I started the car up today for the first time in two days..Man this thing is cold blooded . How is the rest of your cars.. is it a little lean ??
Jamie, what was the ambient temp when you fired it up... E-85 is REAL cold blooded... I wont even attempt it if its 45* or lower(maybe closer to 50*) you have to pump the hell out of it to get it to fire and keep it lit till it gets some temp into the engine
Re: OK 3th try with the E-85 update ( 10-7-11 )
[Re: VernMotor]
#1082228
10/08/11 12:03 AM
10/08/11 12:03 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Making the most out of the little time Jennie let's you drive?
Nice job bud
[Re: MR_P_BODY]
#1082230
10/08/11 12:42 AM
10/08/11 12:42 AM
Posts: 4,069 Mo.
racerx
Mo.
I've started my last Sunday temp. was between 40-45 in the morning u have to pump the h*ll out of it to get it to start and keep it running with the rpm up to get the heat in the motor.
[Re: WILD BILL]
#1082231
10/08/11 10:01 AM
10/08/11 10:01 AM
VernMotor
Mt.Vernon ,Ohio
Nice job bud
I got to keep my 1 win a year streak going !..Jenni can't pick on me to much that way LOL
[Re: VernMotor]
#1082232
10/08/11 10:04 AM
10/08/11 10:04 AM
WILD BILL
BROOK PARK, OH
Nice job bud
What ever you need to tell yourself
[Re: tboomer]
#1082236
10/08/11 11:24 PM
10/08/11 11:24 PM
VernMotor
Mt.Vernon ,Ohio
Bill....Maybe Jenni should drive your car!!
LMAO Now thats funny !!
[Re: 11secondC]
#1082237
10/08/11 11:27 PM
10/08/11 11:27 PM
VernMotor
Mt.Vernon ,Ohio
Did it pick up any?
NO I don't think so..
I just got home from the track..I will fill in with some details tomorrow.. I am too whip right now !
[Re: dartman366]
#1082239
10/09/11 01:13 AM
10/09/11 01:13 AM
WILD BILL
BROOK PARK, OH
Ok, you want a response..
Try this, If for any reason I was to become unable to drive my car, I would be quite proud to have Jennie behind the wheel. At least till one of my own kids was up to the task.
She is by far not only of the better drivers I've met but she is also a great person overall.
I agree that I'm by no means a force to be reckoned with or someone that you should dread lining up against but as long as I can still get behind the wheel I will continue to do my best to hold my own.
Besides, I don't think she could come to terms with dying her hair blue
[Re: WILD BILL]
#1082240
10/09/11 11:04 AM
10/09/11 11:04 AM
VernMotor
Mt.Vernon ,Ohio
Well Now I would not rule that out ! LOL She like blue her racing jacket and gloves are blue and she had me paint her last JR blue.And she had a lics plate made in blue for the back of the car. so the car had some blue on it !! And she realy Like to run in the 10.00 class..So if I was you I would not give her that chance LOL..She just might take you up on it !!...You know if we did't luv ya Bill we would not pic on ya !
[Re: VernMotor]
#1082242
10/09/11 11:32 AM
10/09/11 11:32 AM
WILD BILL
BROOK PARK, OH
Sounds like there's hope for her yet
As for the carb, while I wont pretend to know anything about E85 My Alky carb has a 50 and a 30 cc pump. I think the 50 is in the front but I could be wrong.
Also, a lean out valve is a sure fire method of getting heat in the motor. Getting the oil hot is paramount as I learned at the Mo Power race. Sometimes I would have the LO valve open till I was ready to do my burnout.
I have had to, when it's real cold, pour gas down the throat of the carb to get it to fire for the first time in the morning. After that it wasn't an issue. I've also found that if I give it a pump, then start the motor spinning and then lite it it would fire easier.
I also don't turn the fuel pump on till after the motor is running as Alky can easily overcome the needles and pour out the boosters.
[Re: VernMotor]
#1082243
10/09/11 12:52 PM
10/09/11 12:52 PM
Posts: 2,128 sweden
sshemi
sweden
Now back to this Carb,,Not sure I like it !! the driveability Of this thing $ucks..way too cold blooded and once it wram up trying to give it light throttle it hesitation trying to just move the car a little in the staging lanes the Rpms drop down to far it dies..say below 700-800. It will once warm sit there and idle at 150 deg all day long. but over all it don't run cooler . It is a little slower and and so far I do not see it more consistent. I got away from the hesitation on the line by raising the launch rpms by 300 rpms But that makes it way to easy to red eye..Not good. I now have 90-97 jets and .055 squirters in it with pink cam on #2 hole.Dumping alot of fuel in there. after the run turn off the track look at the Temp it is 205 degs ..180 when I stage 150 pulling in to the water box.I am bout to put 50cc pumps on it ! Not sure what else to do to it
i am suprised that it doesnt already have 50 cc pumps. i pretty sure you have way too much jet in it. Too much fuel will make it stall after a rump. And if you use the 50 cc pumps i bet your hesitation will go away.
Or... if you send me 20$ and the carb ill take care of it.
[Re: VernMotor]
#1082244
10/09/11 02:33 PM
10/09/11 02:33 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I found my old combo wanted a lot of pump shot when I foot braked from 1800 on E85, Ended up with 50cc pumps front and back and 50 shooters. 60' times got better till I ended up there. This was on a Indy headed 408 with a hp950. My you will need at least 1 50cc pump to get the pump shot duration you need(the bigger the shooter the faster the pump is empty) when the carb is happy I think you will be happy with e85's performance/cost.
"Just a Bracket car dressed up like a streetcar"
[Re: 69dart]
#1082256
10/15/11 11:15 AM
10/15/11 11:15 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
as was said bigger squirters empty the pump faster with 30cc pumps. my 950 I put 1 50cc on the front and it got rid of the hes. I think this will be more apparent in cool/cold weather. So makes sure engine is warmed up when you go to wide open throttle. Like the dart man said the single plane manifold is a cold man. I too dump gas in when it's 45* for first start. Something is wrong if you didn't get quicker with E 85. Keep going you will get it. Don
