Re: Anyone replace therostat with restrictor plate?
[Re: Skid_Demon]
#1082153
09/25/11 03:33 PM
09/25/11 03:33 PM
Posts: 15,487 Florida
scratchnfotraction
While talking about a cooling problem, a BBC owner chimed in he replace his good thermostat with a stainless steel washer called a restrictor plate. Same OD as stat and a 5/8 hole in the middle. He claims all his cooling issues went away. Said it slowed down the water flow which allowed radiator to cool fluid more before going back into engine. Anyone else try this?
yes,I have done it a few times.
IMHO,results will vary.
always ran distilled water with a bottle of water wetter with the restrictor plate.
it helped cool my 4x4 when off road at slow speeds with lots of idle time.
its done on roundy round cars a lot with short run cycles.IIRC
Re: Anyone replace thermostat with restrictor plate?
[Re: 69L78Nova]
#1082154
09/25/11 04:02 PM
09/25/11 04:02 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I would think a properly working thermostat would accomplish the same thing
Please stop that crazy talk , a chevy owner masked a possible cooling issue by making the water flow constantly instead of removing heat before flowing thru the radiator ... some people ...
[Re: MoparforLife]
#1082162
09/26/11 02:22 PM
09/26/11 02:22 PM
Triple Threat
Renton Washington
My car doesn't have a thermostat or a restrictor. Just a stock iron pump water pump. I do it for other reasons though, it's easier for me to control engine temp for racing purposes when I don't have to deal with the 'stat opening and closing.
