Some more small block victor head info
#1081330
09/24/11 10:05 AM
09/24/11 10:05 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Good buddy of mine from here local is down in Indy this weekend and had a chance to talk to hughes and look at a protype victor head they have down there. Guess they have a 2.150 intake valve, and 1.60 exhaust. He said it looks very similar on the exhaust port side to a W5 exhaust port. The intake runner is raised quite a bit. The Hughes guys said the head should be capable of flowing 350 cfm. Also said they will take a big block style shaft mount rocker system, and that the cost of these heads shouldnt be much higher than a standard small block Eddie head My buddy was under the impression an indy intake MIGHT be what is used initially. If most of this turns out to be the case, all i can say is wow Supposed to be available next summer hopefully, we will see. Sheesh, a head like that even setting on a flattop slugged pumpgas 340 with some camshaft would even make some serious steam
Re: Some more small block victor head info
[Re: B3422W5]
#1081331
09/24/11 11:05 AM
09/24/11 11:05 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
[Re: B3422W5]
#1081332
09/24/11 11:17 AM
09/24/11 11:17 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I was told that they plan on showing ( releasing?) them at this years PRI show.
RIP Monte Smith
[Re: DakFink]
#1081337
09/25/11 02:45 AM
09/25/11 02:45 AM
Posts: 3,396 Pa
Hot 340
Pa
I'm just hoping that 350cfm is OOTB and not ported. If it is potential looks really good.
ya think?
[Re: emarine01]
#1081338
09/25/11 08:57 AM
09/25/11 08:57 AM
Posts: 2,578 sweden
1Fast340
sweden
All sounds good.... anyone got some pics
X2
this sounds exiting
[Re: Streetwize]
#1081340
09/25/11 06:14 PM
09/25/11 06:14 PM
B3422W5
Portage,michigan
From what my buddy was told, the 350 is the heads potential, not an out of the box number.
[Re: Pat7272]
#1081348
09/26/11 06:10 PM
09/26/11 06:10 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I wish they would have been available when I got my Indybrocks would have been another choice.Although I have no complaints out of them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Pat7272]
#1081349
09/26/11 08:39 PM
09/26/11 08:39 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
A 320-350 cfm head is going to push the power potential of stock SBM blocks with any kind of cam and compression in the build.
I think this new head sounds like a GREAT product! I just think a new block may be in order for a lot of people to really get the most out of the heads.
I saw the model Dave had at INDY. It had 18-bolt provisions.
