Re: PORTER RACING HEADS STAGE II PORT ON BB EDDY'S
[Re: Labratt]
#1081240
09/24/11 12:58 AM
09/24/11 12:58 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
why dont you just ask Dwayne how much it would pick up? FWIW, i think it would be money well spent
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Labratt]
#1081244
09/24/11 11:26 AM
09/24/11 11:26 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Randy, i'm pretty sue Dwayne is getting 310-315cfm on a std port e-head on his bench. You see how well Doug's flat tappet 451 is working with the stage 2 portwork Ron
[Re: 5126brl No more]
#1081246
09/24/11 11:47 AM
09/24/11 11:47 AM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Box them up and send them to Dwayne. You will be glad you did. I imagine you might have to send him the intake to if you are going to have him mill the heads.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: Labratt]
#1081248
09/24/11 12:01 PM
09/24/11 12:01 PM
Posts: 5,160 Texas
dannysbee
Texas
If it were mine I would send him the intake and heads and let him work it all over.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1081249
09/24/11 01:03 PM
09/24/11 01:03 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Dwayne is one of the most respected head Porters and engine builders on thsi site and one of a handful on here that I would never hesitate to recommend. When I recieved my Stage VI Chapman Max Wedge heads and wanted to know the "real skinny" on what I had I knew I could count on Dwayne to give me an Honest an objective technical evaluation, and he did. Generally every 4 cfm of intake you gain throughout your cam/port flow window is worth 1 hp PER cylinder, provided your induction and exhaust system is capable of delivering the proportional increase in Air/fuel demand needed to achieve it. If I recall correctly the PRH Stage 2 on a BB Eddie should deliver at least 30-35 more CFM through the most critical mid-lift flows (where the valve spends 1/2 it's time), so in rough numbers that's about 65-70 more HP potential all else being equal. The effect of a good port job is very similar to the difference in a flat tappet vs a roller of the same relative seat timing and lift...only more so. You are effectively allowing the motor to increase it's VE (torque and as a result HP and upper RPM breathing) but without negatively impacting the lower end of the powerband. It's a win-win and furthermore, Dwayne is one of hte best at tailoring the port work to the specific flow characteristics of the cam and the converter/gearing/vehicle weight of the rest of the combination. bottom line...you can't go wrong with PRH
[Re: Labratt]
#1081254
09/24/11 03:33 PM
09/24/11 03:33 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thanks,Ron! Did these flow 329cfm AFTER Dwayne worked them? If so,what were they flowing BEFORE? I've talked to Dwayne on a few occasions,in fact I purchased my Comp SQ flat tappet cam from him...on his recommendation!...EXCELLENT choice! I picked up .3-.4 from my previous cam. My Eddy's are box stock,except for Isky 8005A springs,and Comp retainers. How do those Max Wedge port windows affect low-end torque on the street? Thanks! Randy
Randy that was 329 @ .600 when they were done and it was 319 @ .550. I dont know what they did stock but Dwayne could tell you. I believe the EZ's are about 295 to 300 stock on the intakes. My low end still works great but I use the Indy dual plane which I like. My only time at the track when I ran the 11.04 with lean problems it has a 1.57 sixty and the hook was not real good. With the 493 cubes it feels great on low end. And that is also why I went with the Indy dual plane to help keep the low end strong as everyone said I would love that Indy dual plane which I do. Ron
[Re: topbrent]
#1081256
09/24/11 04:36 PM
09/24/11 04:36 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I agree but is Jeff back at work, or is he still having treatment. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1081258
09/24/11 04:52 PM
09/24/11 04:52 PM
Posts: 2,325 Clinton Twp... north of Deetro...
Labratt
Good Ol Randy B!
Good Ol Randy B!
Mick..last I heard,Jeff is back at it,but not putting in as many hours as he use to! Chemo and radiation therapy knock your energy level for a loop! Found that out in 2010,when I did chemo,from April to August. I was fortunate though,didn't get real nauseous,lose my hair..or my appetite...but my energy level was terrible! I know for a fact,Jeff's treatments were a lot more intense than mine! I just hope he makes a FULL RECOVERY! Jeff's a GREAT guy! Work..no matter who's it is,has to be secondary to his health!
