Re: Sanding epoxy primer prior to body fill
[Re: 73rrak]
#1080760
09/23/11 10:40 AM
09/23/11 10:40 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I always sand the epoxy off with 80 grit paper ( on a D/A ) and put my filler on bare metal then epoxy over the repair when it's done. If you call the tech # on the filler can I'm sure they will tell you the same thing.
....Most fillers/puttys/etc are polyester based, and don't adhere well to epoxy pased products, primer included, where as epoxy will bond to cured polyester, so do the filler work(bondo) on bare metal, then Epoxy coat/primer
Mike
[Re: 73rrak]
#1080762
09/23/11 11:47 AM
09/23/11 11:47 AM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
[Re: 73rrak]
#1080764
09/23/11 10:38 PM
09/23/11 10:38 PM
Posts: 8,499 Candler,NC / Myrtle Beach, SC
JDMopar
I use PPG DP90LF over bare metal, then let it sit for a few weeks. I then scuff any areas that need filler with 120, but not back to the metal. Then apply and work the filler. Get it slick and then back over the filler with DP90LF. Then begins the K38 and blocking. I did my 71 GY3 Challenger using that process, and it looks as good today as it did 5 years ago when it was painted. No lifting,shrinking or any other problems.
[Re: DaytonaTurbo]
#1080767
09/24/11 04:01 AM
09/24/11 04:01 AM
newem
I always thought putting the epoxy under your filler was supposed to do a better job at complete keeping any moisture away from your metal because the filler can absorb moisture.
Seems from all the positive testimonies out there that either method works out alright. The guy that taught me has been a bodyman for 35 years and he prefers to put the filler on bare steel.
[Re: GLR]
#1080769
09/24/11 10:21 AM
09/24/11 10:21 AM
JDMopar
I have used PPG's epoxy for years...I apply the epoxy over top of the bare steel...let dry for at least 24 hrs and scuff sand with a scuff pad well, clean with cleaner and apply fillers over top of the epoxy. I have been doing it that way for 30+ years..no problems ever and I have also had to repair accident damage after 10 years after the car was restored and the adheasion was great, no rust under any of the filler work either and the owner drove the car a lot, he put 88,000 miles on it since the restoration and it was always outside on nice days all day long in a parking lot.
You and I do it the same way.....but you explained it better than I did.
