starting linebog...wheels up #1080576
09/22/11 07:39 PM
09/22/11 07:39 PM
NW PA
V10nacuda Offline OP
NW PA
B-1 With a dominator
1) fuel pressure is 9 psi doesn't appear to drop at launch.
2) good aeromotive pump & regulator.
3) -12 to the pump...-10 to the regulator..-6 to the garb
4) worked up to 42 shooter still boggs
5) I foot brake the car and leave around 2800.
6) 60' is 1.42 give or. Take .002
7) jet extensions...not the cheap plastic ones..
8) tube connecting both the front & rear breathed made no change.
This darn thing leaves as soon as the front wheels get a few inches up it boggs bad!!!! Picks back up makes power...boggs and then is fine for the rest of the run!!!
I can't figure this thing out...last year it would 60' 1.36 with no bog..
Re: starting linebog...wheels up [Re: V10nacuda] #1080577
09/22/11 07:46 PM
09/22/11 07:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What did you change from last year to now... I seen
this when I was real lean... is the float level good
Re: starting linebog...wheels up [Re: MR_P_BODY] #1080578
09/22/11 08:39 PM
09/22/11 08:39 PM
NW PA
NW PA
Pulled it out of the trailer tried to make a few runs at pittsburgh and it bogged worse and the fuel pressure was all over the place......so I swapped in a complete new fuel system and lines. Added shooter size and the vent tube fix. Fuel level is at the bottom of the site glass....still bogging...
Doesn't a 42 shooter seem large when previously it worked ok with a stock dominator shooter?
Re: starting linebog...wheels up [Re: V10nacuda] #1080579
09/22/11 08:44 PM
09/22/11 08:44 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
not sure about dominators,but i've seen dead spots from the pump cam not being right
Re: starting linebog...wheels up [Re: V10nacuda] #1080580
09/22/11 08:46 PM
09/22/11 08:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use stock squirters in my 1050... check the bleeds
to see if they're plugged... is this on a trans brake
or foot
Re: starting linebog...wheels up [Re: V10nacuda] #1080581
09/22/11 10:21 PM
09/22/11 10:21 PM
To big of squirters can cause a bog also Is this a three circuit carb? If so try enlarging the intermediate air bleeds .020 or more and go down on the suirteres I had a Holley 9375-2 HP that started to bog, got worst when I changed to bigger squirters, change the intermediate bleeds and pick up .4 in the 1/4,.15 in the 60 ft. times Changed back to smaller squirters and pick up a little bit(.002 to .003) in the 60s
Re: starting linebog...wheels up [Re: Cab_Burge] #1080582
09/22/11 11:01 PM
09/22/11 11:01 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Another simple check is the fuel bowl gaskets, I had some swell enough to partially close off certain holes and the car ran like crap, took a couple months of misery til I tried new gaskets and responded with 9.80's!!
Re: starting linebog...wheels up [Re: V10nacuda] #1080583
09/22/11 11:27 PM
09/22/11 11:27 PM
Guitar Jones Offline
How long had it been sitting? I've seen the gaskets dry up and shrink too. Have you opened up the carb and made sure everything is clean and clear?
Re: starting linebog...wheels up [Re: MR_P_BODY] #1080584
09/23/11 02:04 AM
09/23/11 02:04 AM
NW PA
NW PA
I thought the air bleeds were more of function down track...but I will look.
I never thought about the gaskets.....the carb was new but had been on the shelf for awhile when I got it......just figured as long as they don't leak they are good.
This is foot brake deal and is a 3 circuit garb..
Thanks for the suggestions guys I will look at the suggested
areas...
I appreciate the help...I am somewhat carb illiterate
Re: starting linebog...wheels up [Re: V10nacuda] #1080585
09/23/11 02:22 PM
09/23/11 02:22 PM
The three circuit carbs have the intermediate circuit for a reason, that is so us stupid foot brake racers that use them will have to tune that circuit to get the car to leave cleanly Try a biiger air bleed on the intermediate circuit, say .073 or close to that Go back to a 31 squirter after that if the bleed change fixes the bog
Re: starting linebog...wheels up [Re: Cab_Burge] #1080586
10/24/11 10:18 PM
10/24/11 10:18 PM
NW PA
NW PA
Got the gaskets replaced with no. Change...hope to try and get one more outing before snow to try the air bleed.
At least it a consistent bog
Re: starting linebog...wheels up [Re: V10nacuda] #1080587
10/24/11 10:32 PM
10/24/11 10:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How far out are you when it happens(10, 20, 30 feet)
if its right at the line(or damn close) I would think
its not getting fuel... I assume the revs start to
pick up then it falls on its face... did you check
the bleeds... it sounds like its going lean
