How to tell a 5.2 magnum from a 5.9 magnum? #1080541
09/22/11 06:19 PM
09/22/11 06:19 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
Going junkyard shopping and planning to pull a 5.2 magnum from the local u-pull. How do I tell a 5.2 magnum from a 5.9 magnum? I was planning on walking away from this with a 5.2 but if there's a 5.9 there I might just snag one of those.
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: DaytonaTurbo] #1080542
09/22/11 06:28 PM
09/22/11 06:28 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
If it's still in a truck the emissions tag under the hood should say the engine size. I know the LA blocks had 1" tall numbers on the side showing the cid as well, but I don't remember if they still did this on the magnums or not.
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: 440newport] #1080543
09/22/11 06:41 PM
09/22/11 06:41 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
They do. It'll say 318 or 360 on the drivers side of the block under the head, in the same place as an LA
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: 69L78Nova] #1080544
09/22/11 08:33 PM
09/22/11 08:33 PM
Manitoba, Canada
Manitoba, Canada
Thanks!
Where exactly is this? On the front of the block or on the side by the exhaust manifold? And am I going to be able to see it when the motor's in the vehicle and complete with accessories?
Don't laugh too hard, I haven't owned a small block in 10 years!
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: DaytonaTurbo] #1080545
09/22/11 08:58 PM
09/22/11 08:58 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Under the exhaust manifold, toward the rear. Roughly two inches down from the deck surface.
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: DaytonaTurbo] #1080546
09/22/11 08:59 PM
09/22/11 08:59 PM
440newport Offline
440newport  Offline
On the driver side of the block above the core plugs, towards the rear. Your view of them will probably be blocked between the starter and exhaust manifold when looking from above. Maybe crawl underneath and see?
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: 440newport] #1080547
09/22/11 09:36 PM
09/22/11 09:36 PM
Manitoba, Canada
Manitoba, Canada
How about what VIN digit/letter to look for on a mid 90's ram or ram van? (assuming the emissions tag is gone) Then I can at least have an indicator as to whether it's worth crawling underneath to check the block for confirmation.
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: DaytonaTurbo] #1080548
09/22/11 10:06 PM
09/22/11 10:06 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
318's have a Y in the VIN, 360's have a Z in the VIN, I think its the 8th character or close to it.
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: MoparJoe] #1080549
09/23/11 12:02 AM
09/23/11 12:02 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yup
But if looking at Vins to I'd it, the emissions stickers will say the size of the engine.
**Photobucket sucks**
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: 70Cuda383] #1080550
09/23/11 01:41 PM
09/23/11 01:41 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
There is also an identification on a magnum block on the front of the block right below the deck on the driver side. it's hard to read usually because of crud, or paint but it's there. Looks like it's lazer etched. it's not stamped.
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: POS Dakota] #1080551
09/23/11 06:03 PM
09/23/11 06:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You can also look at the damper and see if it has a big notch out of one side for balancing it. If the tranny is gone you can look and see if it has a 360 flex plate, you can tell because it has a big balance weight welded to one side.
Re: How to tell a 5.2 magnum from a 5.9 magnum? [Re: HotRodDave] #1080552
09/24/11 02:45 AM
09/24/11 02:45 AM
Manitoba, Canada
Manitoba, Canada
Okay thanks guys!
