Re: Isky EZ Roll compared to Comp roller lifters
[Re: Steve Reynolds]
#1080321
09/22/11 08:19 AM
09/22/11 08:19 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Only thing about changing lifter brands is that there is "No Standard" in push rod cup height. Chances are you will need diff push rods too. I personally like the 829 Comp Lifters, never had trouble, and run 750-800 lbs open pressure. I just check them on a regular basis, and replace them after 250-300 pass's. I cant comment on the Isky lifters.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Mopar_Rich]
#1080331
09/23/11 03:47 PM
09/23/11 03:47 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
I recently purchased a set of the Comp Cams Elite and I am very unhappy with them, they failed on the 5th dyno pass, link bar broke in half on one pair, killed the pair and the 55mm cam. Link bar on every remaining pair is bent. Total waste of $1000. We got away from the 829's a few years ago, the needles were always failing. For the valvetrain weight and springs of our hemi SS stuff, only the Jesel keyway and Jesel dogbone have lived, 5 years+ on same set, no failures. Comp 829's wouldn't last 20 runs.
Be a Rebel- Break the Laws of Physics!
