Re: A Body Caltrac Users...
[Re: moparniac]
#1080263
09/22/11 09:40 AM
09/22/11 09:40 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
69 Dart, Full interior, 3375# with me, 427 sm block, 29/13.5 QTP tires at 12 3/4 psi, Cal track mono springs 1"+ low, Cal track bars lower hole with 2 flats preload, Rancho shocks on 5 Most of the time. I leave at 1800 f.b. or 3400 t.b. best 60' 1.37, norm 1.40 newer tire , 1.42 norm older tire on a good track not stupid hot.
[Re: Just-a-dart]
#1080264
09/22/11 12:17 PM
09/22/11 12:17 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
69 Dart 3134# w/driver. Cal Trac mono's +1", Rancho 9 ways set on 5. Qa-1 12 ways up frt set at 1. Lower hole 1/8" air gap. 4.56 Dana 12x29.5 Gdyr's. 60's 1.47-1.48 Jim
[Re: moparniac]
#1080265
09/22/11 03:34 PM
09/22/11 03:34 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
69 Dart, 3260# street/strip, Cal-Tracs, Monos, Rancho 9 ways on back set on 5 most of the time, 2 flats preload on both sides, set in lower hole, CE 3 ways on the front set on 90/10, the car has 5 1/2" suspension travel in the front. Strange S-60 with 4.10 gears
1.38 60' on 325/50 ET Street Radials, 17.5 lbs, leaving at 2000, foot brake.
[Re: justinp61]
#1080266
09/22/11 05:09 PM
09/22/11 05:09 PM
Posts: 401 dayton,ohio
ROSSIO
dayton,ohio
1970 dart 3330lbs +1,upper hole-"o"preload,leaving @4300 transbrake 4 1/2 frt travel-QA1 frt----rancho 9 set at 6-7--Moser 60-4.56gears 1.30 60ft---29.5x10.5 non"w" M/T stiffwall slicks-11 lbs- ALL MOTOR--8.90's @ 152mph cal tracs--love them
ross
1970 DART B1MC N/A
8.86@ [Email]155
3200 lb on 275 DR
5.30 @ 130 1/8
