Re: Drag Radial or Bias Ply for Heavy 4spd Car?
[Re: Triple Threat]
#1080057
09/21/11 11:17 PM
09/21/11 11:17 PM
Posts: 6,570 San Francisco Ca
SCATPK
San Francisco Ca
What would be a good size bias ply that is equal in size to a 325-50-15?
28x13.5x15 is the comparable bias ply.
Thanks!
[Re: SCATPK]
#1080060
09/22/11 12:06 AM
09/22/11 12:06 AM
Triple Threat
Renton Washington
Section width on the M/T 325/50 is 13.1" Section width on the M/T 28x13.5 is 13.2" Section width on the M/T 28x12.5 is 12.6" Section width on the Hoosier QTP 28x13.5 is 12.9"
Bias ply is going to flex more since the side wall is softer, so any of the 13.5's may rub. Sounds like you should go with the 12.5" tire to gain a little clearance. How much room do you have to the front of the wheel well? Bias ply will grow in height as well at speed. If you have 1/2 inch or more I wouldn't worry one bit.
[Re: SCATPK]
#1080064
09/22/11 12:34 AM
09/22/11 12:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have at least a 1/2 inch of room so should be good. How are the hoosiers in comparison to the m/t`s?
The QTP bits better than the M/T but it also have a shorter life span... ran them both at drag week in the past
[Re: SCATPK]
#1080066
09/22/11 12:39 AM
09/22/11 12:39 AM
MR_P_BODY
So it seems that a bias ply is the way to go and just pick one that fits best for my application. I am going to compare the various tires sizes and pick one that will fit the best. Again I appreciate the feedback guys!
the side wall on the bias tire can take shock better (not as stiff)
[Re: SCATPK]
#1080068
09/22/11 08:25 AM
09/22/11 08:25 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Radials not recomended for stick car.
JAKES AUTOMOTIVE
